  New Posts New Posts RSS Feed - Pd 1850 tuned lower?
prestigedjsdk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Topic: Pd 1850 tuned lower?
    Posted: 08 July 2014 at 7:13am
Hi all. Is it possible to redesign and tune the 1850 horn lower så i will hit 40-30ish? I think 50 is way too high. Hope you guys can help because the saw is ready to make some dust.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 7:15am
build 4 x Startec SBH
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 8:13am
Do you have a link for the plan for those? Will they work with pd.1850s? I am planing on a rig with 2 subs pr side and a crown ma5000vz to run them. What kind of sound could i make with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 8:23am
Just saw the started sbh.
I forgot to mention that these speakers are gonna be used for mobile djing, there for having 4 3meter long subs is not an option
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 8:45am
then you want the cubo 18 Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 8:50am
cubo 18 for pd1850 is shit as a sub http://www.freespeakerplans.com/bass-cabinets/11-cubo-18 it only works from 85hz to 145hz that is not what i call a sub Cry
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 8:54am
nah man, she'll be right. they'll go low enough for mobile disco Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 8:58am
I allready have 2 cubo 18 ext. And they dont hit the low hz unless i eq the hell out of them. And that is not good at all. But yes there is a lot of spl just not al much musical spl
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 9:18am
i was looking at mach slingshot ms 118 are they really the best use for at compact low pd1850 sub?
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 9:50am
You must remember that for a true horn to hit low, it has to be pretty long.
ape3435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ape3435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 10:01am
Yes you can, but it will end up looking like a bass reflex
Post Options Post Options   Thanks (0) Thanks(0)   Quote prestigedjsdk Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2014 at 10:10am
Do you have any data on a double pd1850 reflex?
