  New Posts New Posts RSS Feed - pd 1851
pd 1851
 Post Reply Post Reply Page  <1 2345>
Fabianm_be View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 1:44pm
Very nice build Smile
catalin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 6:29pm
Hi there! I have one question: It is ncessary undercoat or primer before paint?
And second one: Warnex or Tuffcab?
Thanks
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 6:36pm
No
Warnex seems to be more durable but isn't available in all those fancy colors.
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 6:59pm
No
<span style="line-height: 1.4;">
</span>And second one: Warnex or Tuffcab?
</span>
<span style="line-height: 1.4;">Warnex seems to be more durable but isn't available in all those fancy colors.</span>
It is but you need to order 120 Kg. :)
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2014 at 1:43pm
Somme paint jobSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 22 August 2014 at 10:45am
Almost there!!
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 22 August 2014 at 7:09pm
Whats the recess for?
Mykey Wattco
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2014 at 10:54am
Hi there
The recess are for somme metal elements , wich is gonna hold  the mid cab above.
Tigersonics View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tigersonics Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2014 at 4:28pm
That's some really nice wood work! Are you in the UK? If you are, please may I know where you got the grilles?
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2014 at 5:31pm
Hi there!
This are the grills
http://www.rmig.com/en/stock+list/perforated+sheets/online+stocklist+in+rmig+uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tigersonics Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2014 at 1:18am
Ah, I see. If it isn't too much to asks, how much did you pay per grille?
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2014 at 2:20pm
I need four grilles 930 mm/615 mm so i bought two sheets 2000 mm/1000 mm ,47 quid +VAT each
8 mm holes
1.5 mm thick
10 mm triangular pitch
58 % open area
