  New Posts New Posts RSS Feed - pd.186/2 ?
pd.186/2 ?
stephan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stephan Quote  Post ReplyReply Direct Link To This Post Topic: pd.186/2 ?
    Posted: 16 November 2013 at 9:50pm
Hello,
i want to built some 186 horns but i only can get the newer pd.186/2 drivers with different TSP. Is it possible to use these for good results?
Thank you!
PD.186                               PD.186/2
Fs 27 Hz                              Fs 34 Hz
Re 5.5 Ohms                        Re 6.19 Ω
Qts 0.312                            Qts 0.52
Qms 7.75                            Qms 10.77
Qes 0.326                           Qes 0.55
Vas 353 Litres                      Vas 195 litres
Mms 184 g                          Mms 203 grams
Sd 1150 cm2                       Sd 1134 cm2
Cms 188 μm/N                    Cms 106 μmn
BL 22.94 T/m                      BL 22.2 T/m
Xmax 10.5 mm                   Xmax 10.5 mm
Vd 1.20 Litres                      Vd 1.20 litres
Reference Efficiency 2.05 % Reference Efficiency 2.05%
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2013 at 10:17pm
Originally posted by stephan stephan wrote:
Hello,
Thank you!
PD.186                           PD.186/2
Fs 27 Hz                         Fs 34 Hz
Qts 0.312                        Qts 0.52
Qms 7.75                         Qms 10.77
Qes 0.326                        Qes 0.55
Reference Efficiency 2.05 %      Reference Efficiency 1.33%
Just corrected that for you.
http://www.mh-audio.nl/Reference.asp
Wink
Edited by levyte357- - 17 November 2013 at 12:22am
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 5:56pm
when did you get your last 186's if you got them in the last 5 years or so, they are the same as the new ones, the 2 denotes a new chassis, this has no effect on sound..... the specs inherited by pd from the original owners jbl were wrong....
ReubGold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ReubGold Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 6:11pm
new pd 186 sound nothing like the old one. Dead
If he turns me into a zombie, first person I'm coming after is you.
Dref View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dref Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2013 at 4:33pm
Regarding the original question. If you are going to buy drivers for a horn I would look at something else than the new PD186.
Btw. some one must own both old and new PD186s and be able to do a comparison?
A proper build subwoofer will be the only thing in a room that is not shaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stephan Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2013 at 7:34pm
http://www.mh-audio.nl/Reference.asp - http://www.mh-audio.nl/Reference.asp
Wink
thx, i will forward it to precision device ;)
i think i look for another driver.
i liked the pd.186 because it doesn`t need so much amping like other recommended 18" drivers
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2013 at 8:00pm
and the edges on the magnet plates are rounded now on all mk2's..
CritikalMass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2013 at 7:49pm
Are these new drivers no good for the folded horn enclosure (186)
Post Options Post Options   Thanks (0) Thanks(0)   Quote stephan Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2013 at 9:27pm
i`m very interested too, but i think the very different spec`s are not a good sign..
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2013 at 8:02pm
I'd agree...what to do! Was looking to buy four pd186's in a few months!
