  New Posts New Posts RSS Feed - PD 186 4ohm or 8ohm?
_banksy_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Topic: PD 186 4ohm or 8ohm?
    Posted: 24 January 2010 at 3:49pm
As the title says, whats better to load the 186 with? a 4ohm or 8ohm pd186 speaker. This might seem like a silly question, but whats the difference?
cheers.
will
BreakBeat!
Naff_monk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naff_monk Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 10:19am
Depends on how many you want to run and how you're planning to amp them. I would say that 8r is usually more common atm coz that means you can get 2 per channel at 4r (Ohms/number of speakers). If you're using it on 2r per channel, you will get more from your amp but the stability of running amps in this mode for bass is a bit of a controversial subject and could result in you cooking your amp Wink.
Edited by Naff_monk - 26 January 2010 at 11:24am
This page was generated in 0.098 seconds.
