  New Posts New Posts RSS Feed - Phase Plugs
Phase Plugs
Line Array View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Line Array Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2025 at 3:09am
Originally posted by Augusts Augusts wrote:
My goal ir good horizontal dispersion up tp 3-4kHz from an 8" or 10".
you could just use a BMS compression midrange - those are optimized exactly to go to 3-4 khz using a 1.4" to 2" throat horn.
at the low end they will go down to about 800 hz easily at which point you can cross over to a 10" midrange without any phase plugs and still have wide dispersion.
yes you just made things more expensive but you gotta pay to play right ?
and in any case i don't think taking a 10" to 4 khz is realistic.  JBL uses phase plugs on their 8" CMCD drivers but only takes them to about 2 khz.
