Piezo tweeters? |
Page <123> |
studio45
Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3881 |
Posted: 04 May 2013 at 11:59am |
Not much more sensitive. I made a crazy thing last year to take to festivals; I wanted to have the lightest weight and highest output mid-top possible using what was "to hand" in the workshop. This ended up being based around an old Toa factory announcement re-entrant horn. I used Motorola piezos for tweeter duties as I had a bunch of them on the shelf recently removed from a client's old boxes. I started off with two. This was not enough so I added two more. Half an hour later I had ten of the buggers wired up. The system was still not balanced so I then started power shaping the horn (put a midrange cut filter and l-pad on it). Eventually I achieved a good balance and with some use of bitumen damping sheet managed to make the horn sound not like a tannoy horn. But yeah, it took ten Motorolas to keep up, so plan on using at least 4 per 8" unless you want to pad down the 8 and waste some power.
Dub Specialist
Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3235 |
Posted: 04 May 2013 at 12:24pm |
want to throw this up too regarding piezos ect got quite a few from over the years just keep them still
done a lot of testing myself of piezos (all original KSN 1005 & KSN cts 1165 Powerline) not the cheap copys now that thay sell just out of interest and still find them intriguing to how people set theres up ect, and i have to say i seen nuff sounds using them still today so if peizos act like capacitance & impedance changes drastically with frequency so ive read ect im far far any expert in this just to say, but will you get any frequency shift using a passive x/o? you shouldnt as there is no impedance? so ive tested of my head think the box had 18/20 1005 piezos in it using a 5kHz 18db/oct high pass and thay sounded very sweat indeed has anyone got any idea/opinions that there is any problems in using it like this? many thanks
studio45
Posted: 04 May 2013 at 2:40pm |
The impedance of a capacitor decreases with increasing frequency. The larger the value, the faster the impedance falls. Piezos are small value capacitors. At some point up in the near-radio frequencies (way above 20kHz) the impedance will have fallen to a very small value, near zero ohms or an AC short circuit. This can cause some amps to go nuts, oscillate and blow themselves up, and some amps to produce a harsh sound because of instability caused by the impedance dip affecting reproduction in the audio band.
However, the impedance can be thought of as a relatively constant high value - 1000's of ohms - in the audio band. Thus paralleling up many piezos, still doesn't bring the impedance down to normal coil speaker values.
The output of the piezo is proportional to the voltage across it and they pass only a very small amount of current. So if you put an 8 ohm power resistor across (in parallel with) your piezo bank, the whole bank will then effectively be an 8 ohm resistive load. The resistor will be dissipating most of the power, but the piezos will respond to the voltage across it. Depending on how many piezos are being used, it might need to be quite a big resistor, like 50 watts. Finally, to guard against possible 100kHz+ oscillation because of the impedance dip, put a 20 ohm power resistor in series with the piezos after the 8 ohm parallel resistor. This resistor will not dissipate much power, so can be a bit smaller, like 10 watts.
(in+)----------(20R)------(piezo bank +) | (8R) | (in-)-----------------------(piezo bank -) You can then feed this from a standard 5kHz 8 ohm crossover board, and the piezos will only see 5kHz+. If you just hook them up without the resistors, the crossover filters will not be terminated properly and will let lower frequencies through. Edited by studio45 - 04 May 2013 at 2:40pm |
Dub Specialist
Posted: 04 May 2013 at 3:10pm |
Thanks for the Indepth Knowledge/repley Very Intersting
ive noticed that to with the boxes iv accumulated for repair/given over the years that there were a power resister across the terminal like 10r/27r 3/10w but like you say according to how many piezos wired in parallel the values were higher ect thanks ...
RealitySound
Joined: 01 February 2011 Location: Bermuda Status: Offline Points: 1142 |
Posted: 04 May 2013 at 11:58pm |
How would you get piezos to play above a 2 inch comp horn? For instance the horn will play up to 18 k, and the piezos 18k +? thanks.. |
When you gonna send me some $$ mate ?
studio45
Posted: 05 May 2013 at 12:41pm |
No a piezo won't play 18kHz+, the response has dropped off by then. 7k-18k is where they work best. There is usually a large spike in the response at around 16k which is responsible for their "sparkly" sound, but don't get confused about what frequencies are what.
Also what 2" horn have you got that plays up to 18k? Must be a really nice one to get that high, probably sounds fine on its own
RealitySound
Posted: 05 May 2013 at 1:52pm |
Using this horn- http://www.parts-express.com/pe/showdetl.cfm?partnumber=294-808
loaded with- http://www.parts-express.com/pe/showdetl.cfm?partnumber=294-615 piezos- http://www.parts-express.com/pe/showdetl.cfm?partnumber=292-442 |
studio45
Posted: 06 May 2013 at 12:06pm |
Yeah, I reckon piezos are a bit of a waste of time if you have that horn and driver. I would say you need bullet tweeters to add anything meaningful to what the DE750 can already do. In fact if you just use a bit of EQ on the very top end, you should be able to get the same response as if you added extra tweeters.
RealitySound
Posted: 06 May 2013 at 1:29pm |
King Simeon
Joined: 13 January 2007 Location: United Kingdom Status: Offline Points: 794 |
Posted: 06 May 2013 at 3:11pm |
A capacitor is a good idea, it will give a gradual slope, acting like a hi pass filter. Try different values, from 1 up to 4.7 and listen to the balance when playing with the horn.
studio45
Posted: 07 May 2013 at 12:43pm |
Well, you could use the circuit I posted above, with the 8 ohm and 20 ohm resistors, but use a 10KHz highpass filter instead of a 5k.
Four piezos will still not make a dent in the VHF response of that system, the horn will be much louder on its own. To make the horn balance with the piezos you will need to pad it down loads, and thus waste loads of power. Piezos are very quiet, that horn is very loud, it's not a good match. You could always block up those holes you know. And I can show you how to build a passive crossover that EQ's up the very top end of the horn....
RealitySound
Posted: 07 May 2013 at 12:48pm |
I have some small B&C tweeters, going to see if they fit.....
Page <123> |
