  New Posts New Posts RSS Feed - Planar Wave horn
Planar Wave horn
 Post Reply Post Reply Page  123 22>
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Topic: Planar Wave horn
    Posted: 12 March 2006 at 4:57am
It looks like I'll have some new toys for a few days
I have a custom order for some really powerfull subs
Planar wave horn plan
the sub used will be Selenium 18SW1P
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7& Partnumber=264-438&ctab=10
Edited by Nexus_3 - 01 April 2006 at 3:01pm
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2006 at 4:58am
I'll post some pics as I'll build them next week
Ex Nexus_3
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2006 at 5:25am
Planar horn bass reflex?
18" on BR,decent anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2006 at 5:40am
it's a design derived from dynacord Planar wave horn subs
the port ending outside the waveguide helps achieve better subbass reproduction
horn coupling is not necesary
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2006 at 8:58pm
Ah yes i remember that sub now. When you do make some,could you measure its impedence vs frequency etc? Im interested in how that short tunnel helps it at all.
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2006 at 2:28pm
COOL horn expansion rate  - PV Low Rider (if meet spec) look like a drop-in substitute for US cheapass.  Are PV Low Rider 18 OK?  -- I've 1808 and they are way off specification so are now "open baffle woofer"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2006 at 2:54pm
one way of testing if other speakers work in the design is this one:
because there is no speaker simulation program capable to polt this design we have to work around that.
1. plot this speaker in bass box as a simple bassreflex box (no horn)
2. load another driver in that enclosure and try to reach the same plot
3. when you have identical plots then it should work ok in the planar horn.
modifications to the reflex ports will be necesary
I know that P-audio c18-650EL works in this design , but you have to shorten the ports by 110 milimeters
Edited by Nexus_3 - 13 March 2006 at 2:56pm
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2006 at 7:19pm
Freddy - Easier to make a K?
Whatabout d&B B2 patent? I want to try it,measure impedence etc,even if it just makes a nice 45hz !
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2006 at 10:28pm
does anyone know where i can get the full plan of the sub above? Those are really easy to make. Just move the baffle half way....
I have heard those (dynacords) in stacks of 6 per side during an outdoor concert in a square. Rattled my glass of wine in the bar i was in.
Edited by djstefanos - 13 March 2006 at 10:34pm
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2006 at 5:44am
probably a silly question, but i'm assuming to load the driver you shimmy it
past the mouth brace and then climb half in side the cab to bolt it in?
pictures would indeed be nice, plots would be nicer.
james.
mardy hippy.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2006 at 8:14am
are they actualy that simple/good? im interested in finding out more!
Peter Moller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Moller Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2006 at 5:11pm
2 questions:
Can you explain the hornloading part of this box?.. In other words: How do I do the math to design that horn?... Are we talking Helmholz resonators or ?
Why does the handles on your drawing say "Cobra PWH" :-)... Did you measure a PWH sub or are you just using the outside dimensions and retuning it to suit the Selenium driver?
/peter
This page was generated in 0.111 seconds.
