"Polar Bear" Scoop build |
Page <1234 9> |
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 13 July 2010 at 1:36pm |
Nice pics, ![]() How do they sound? |
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Posted: 13 July 2010 at 2:40pm |
Well, I really cannot comment on how they sound compared to other scoops as I haven't heard any other than what was in last Notting Hill Carnival (A.S.S was in different league compared to others, missed Aba Shanti I though). I think they really need a bit of EQing around 40-60hz area, that is if I really really want that same "flavour" and warmth as Kayak had with his ASS float. Of course these sound well heavy without EQ too. They are definitely on a par with 1850 horn what it comes to sensitivity. We are driving both with same amplifiers and both are loaded with V18, so easy comparison. We use these for 30-70hz and 1850 from 70 to 120, we may push them to 130 or 140hz at some point just for fun.
What do you consider as large / medium / small chamber in scoops, Lev? These ones have around 60 liter chamber |
levyte357
Posted: 13 July 2010 at 3:04pm |
IMHO, would class small chamber as <55L, 55-65L as Medium Chamber, and >65L as large chamber. |
JR.junior
Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
Posted: 13 July 2010 at 3:17pm |
ASS S118 has around 53L - small chamber. around 60 is medium, around 70 is large. To calculate chamber volume, I need inner width (600mm?), distance for inner baffle and throat oppening.Edited by JR.junior - 17 March 2016 at 1:43pm |
pfly
Posted: 13 July 2010 at 3:52pm |
JR I've already done that.
Actually 60 liter was with driver. It is 71 liters without driver |
JR.junior
Posted: 13 July 2010 at 4:55pm |
HR plots? ;)
levyte357
Posted: 13 July 2010 at 5:02pm |
Driver with larger Vas than V18-1000, would really make use of that larger chamber. However, would also need min BL=25/Xmax=12, Think you should try one of these in there... ![]() http://forum.speakerplans.com/2x-18-turbomax-1000-drivers-fane-chassis_topic41060.html |
pfly
Posted: 13 July 2010 at 5:41pm |
I'm thinking more of these:
http://bmsspeakers.com/cone-speaker-compression-driver/bms-neodymium-cone-speakers/bms-neodymium-cone-extended-low/bms-18n860-neodymium-woofer/18n860-woofer-t-s-parameters/ ![]() back to V18-1000: 2pi / 2,83v ![]() 0,5pi / 2,83v ![]() Edited by pfly - 13 July 2010 at 5:52pm |
JR.junior
Posted: 13 July 2010 at 6:04pm |
18N860; realy slow dynamik speaker. EPB 62, Qts 0,37 Mms 277g, this is not good horn driver, great for BR..
pfly
Posted: 13 July 2010 at 6:11pm |
Just check out what 18N850 does in Hogs
![]() Tony Wilkes tested two with Smithers' Hogs I believe. ...On the other hand you are kind of right, but then again scoop isn't the most typical horn. My guess is that 18N860 has large enough VAS and just enough of BL to work in there, it sims a bit poorer than V18-1000 though. It would be really interesting to compare 18N850, 18N860 and V18-1000 in my scoop Edited by pfly - 13 July 2010 at 6:18pm |
JR.junior
Posted: 13 July 2010 at 6:14pm |
I have to, it's much better driver.
Edited by JR.junior - 13 July 2010 at 6:19pm |
levyte357
Posted: 13 July 2010 at 6:57pm |
Sims only tell you half the story, and are often very optimistic.
From 1st hand experience, can tell you Turbomax 1000/Fane 18-1000 sounds better than PD 1850/V18-1000 in all the medium chamber scoops I have heard. They are basically more musical/flatter response. With true Xmax evidenced, by smooth sound, even at high power with plenty of Eq. The very expensive B&C Neo was a joke compared to the above. If new/used Neos provided same price performance ratio as Turbomax 1000/Fane 18-1000, would definetly be more interested iin them. EDIT:Compared to the weight of PD1850, the Turbomax is a Neo. ![]() Edited by levyte357 - 13 July 2010 at 7:00pm |
Page <1234 9> |
