  New Posts New Posts RSS Feed - "Polar Bear" Scoop build
 Post Reply Post Reply Page  <1 6789>
fat_brstd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2025 at 3:19am
It seems strange to me, the hundreds of requests for this plan over the years, where as, a perfectly acceptable, free 18" Scoop plan, alternative to the Superscooper 18", is also freely available, on this site, that people are building.
It's because Sinai used them on his mark 1 rig and built quite a reputation with them so loads of people want to have them. Also the allure of not being able to get the design just adds to the drive to get the plans, much like an unreleased piece of music that everyone chases down.
They are great scoops for sure, my wife has 8 of them and they definitely get the job done.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
deepstonesound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deepstonesound Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2025 at 2:04pm
levyte357 can you guide me to the superscooper alternative ?
thank a lot
Edited by deepstonesound - 26 September 2025 at 2:04pm
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2025 at 3:36pm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2025 at 2:20pm
The precise plan I was talking about.
personally suggest the Superscooper 18 for Void V18-1000s,
The Mykey "Scaled up Fane", for everything else.
The "Knowledgeable", will modify Mykey plan, to suit their driver of choice...
Post Options Post Options   Thanks (0) Thanks(0)   Quote deepstonesound Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2025 at 4:56pm
thank you
i plan to build only 2 or 3 scoop stack, and maybe should be better with mykey scoop than superscooper ?
thank again
Edited by deepstonesound - 03 October 2025 at 3:41pm
mchw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mchw Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2025 at 6:01pm
I'm planning on building four scoops too for dub and dubstep and its clear that polar bears are not an option. I already have 4 pd1850/2 but will probably upgrade later. Would mogale or mykey be better?
StoneGrove View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StoneGrove Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2025 at 6:20pm
I will save you the time based on the responses over the last few months. The MyKey design is the superior updated design proven and available.
mchw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mchw Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2025 at 12:41pm
In what way does it compare to mogales? Because for me it's very important that in a group of 4, it can reach around 30hz and has good SPL. The Mykeys look easier to build too as I don't have to do the curved sections.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2025 at 2:03pm
Neither scoop will hit around 30 with authority especially with just four , a stack of six hogs struggles with that with a bit of a longer horn path.
And with authority I mean with the same impact and feeling as 40+ hz.
If you don't want to build and maybe buy new scoops check out the stakx scoop it has a bit of wizardry in the chamber and a bit longer horn .
HumbleDeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HumbleDeer Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2025 at 1:19pm
Originally posted by Sypa Sypa wrote:
If you don't want to build and maybe buy new scoops check out the stakx scoop it has a bit of wizardry in the chamber and a bit longer horn.
I've known Frederik for many many years now and we both respect each other and our skills from what I can tell.
From knowing the internal structure of the scoop he's got, there's nothing super complicated going on. What's happening is shuffling things around to basically circumvent that otherwise fixed width-wise dimension. With the split entry to the horn, you don't really change the behaviour -- not at these frequencies. You could move them all to one side and they'd behave the same as a horn.
But not in the chamber as horn throats! If you'd merge them you'd get a different response *because* of the fact the speaker is in a chamber that has its own feelings and thoughts err physics too.
So this split throat, extra extension of that tube, and so forth allows:
- Allow the total cross sectional area of the throat/entrance to be smaller
- ^While not restricting the outflow to the horn of the lowest frequencies (the aspect ratio of the tubes is responsible for that)
- Circumvents the part where in older designs, the chamber and throat are otherwise very indistinct, so making the throat larger would actually steal part of your chamber too. The size of the opening you need for large bass waves to pass through in say a superscooper would make the cross sectional area so huge that it also poses lower resistance to the driver.
- Hence this allows the higher compression ratio and driver control of a smaller throat entry, without the compromise on your low end you'd get from a very wide, but narrow in height slot of a superscooper.
Does this help with the "special magic"? It's not complicated or advanced new acoustics. It's just a case of cleverly rearranging the cross sections and such, and observing that doing as such (and as done in the SH118) slightly decouples the chamber size and behaviour and the compression ratio and the side effects of narrowing the opening of your throat (which is your only way of reducing the cross sectional area total with a fixed width!)
If that still doesn't make more sense, then.. I can't help, but I can give other examples of speakers that have done this. Say, the Jensen Imperial with its internal left and right exits out of the chamber that then merge into a large horn.
(I lost track of my train of thought forgive me)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2025 at 1:21pm
I would argue, no 18" Scoop is going to hit 30hz with authority, even in a stack of 6x.
Anyone who says a Scoop must play 30hz, and not mention with which driver, does not know what they are talking about.
Even if loaded with a wonder 18" driver, in building with immaculate mains supply, and if the crew are using the best amps money can buy.
And let's face it, most crews are not using €600 drivers, or Powersoft X4L amps, or playing in venues with 3ph power.
if a Scoop system can play down to 38hz with authority, with 4x Scoop stacks, nothing will sound like it is missing, and most people will think it is playing lower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2025 at 2:03pm
Firstly, I would  suggest selling the 1850/2 now, and getting 1851s.
Only driver I liked better than PD 1851s, are 18NLW9601.
I would suggest the Mykey plan, 738mm depth version. with following mods,
  • Make cab 636mm wide,
  • Reduce front baffle depth from 36mm to 18mm
