Poorly Yamaha REV500 |
Jimmer
Joined: 30 April 2010 Location: Stroud / Glos Status: Offline Points: 2604 |
Topic: Poorly Yamaha REV500Posted: 12 September 2016 at 9:17pm |
Evening Chaps!
I have a Yamaha Rev500 that's taken a whack to the input potentiometer. Needs a new one as its completely obliterated! I have sourced the service document and it is a Panasonic EVJC20 10Kohm 2gang, which of course is now discontinued and not in stock with farnell. (never easy is it!!)So my question is do any of you fine gentlemen have any knocking around the shed, or can anyone recommend a suitable replacement? Thanks in advance! Jimmer
Jimmer
Posted: 14 October 2016 at 1:41pm |
Anyone able to help? before i solder two resistors in its place!
odc04r
Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5469 |
Posted: 14 October 2016 at 2:08pm |
Do you know the full device number? From a quick browse it looks like it might be a 14mm wide pot? If so Alps have a 14mm range too which look fairly similar in pinout (a lot of pots do have similar footprints).
Is it a dual log 10k pot? If so a part that might do is RK14K12A0A3C (no bushing) or RK14K12B0A0E (with bushing). |
Jimmer
Posted: 14 October 2016 at 2:29pm |
Top man, on a quick look they look promising
Just popping out but will double check later and see if they'll do the trick....cheers Bud
CASTANEDA
Joined: 30 January 2025 Location: TINONEE Status: Offline Points: 1 |
Posted: 30 January 2025 at 1:25am |
Hi mate!
I have exactly the same problem (my REV500 hit the floor during a bump in at the Australian Hotel, Wingham) and the input pot is terminally smashed. Were you able to source a replacement EVJC20 10Kohm 2gang or did you end up wiring in a pair of 5ks instead? The Alpine equivalent pot is proving tricky to source! Cheers - Dean
