Porn Horn skeleton |
Bob@DAE
Registered User Joined: 18 September 2006 Location: Paris, France Status: Offline Points: 10 |
Posted: 07 February 2007 at 7:21pm |
Hi
I would like to know if the new Porn Horn can be use as a skeleton. The idea would be to hang the horn in a metal frame or fix the front of the horn to the frame and hang the speaker with chains or cables. a drawing to understand my vision of the frame. http://img254.imageshack.us/my.php?image=horncadrezp1.jpg Thanks for any advices and sorry for my (poor) english. Edited by Bob@DAE - 07 February 2007 at 7:23pm |
norty303
With the forthcoming Porn Horn MkII you should have no problem having a skeleton frame, as it has its own integral rear chamber. The MkI didn't have this chamber so would've made things a bit more complicated as you'd need to fabricate a rear chamber for it.
Bob@DAE
Ok, thanks for the answer. I think i'll do a steel frame with square tubes.
I was also wondering how much watts amplifiers should i use. How many watts the P.Audio can hold ??? |
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
probly about 500 odd
CELTIC SUBSONIC SOUND SYSTEMS
odc04r
I know its a pain to weld compared to steel but would an Al frame not be better on the whole weigth wise?
COWFOOT
Registered User Joined: 26 September 2005 Status: Offline Points: 1088 |
Aluminium is lighter no doubt but you're gonna be using a small amount of metal so the weight difference shouldn't be material unless you're a weakling to begin with.
Bob@DAE
At last, i won't build it in a skeleton. I'll use birch plywood.
Does anyone know when the Horns (12" + 1") will be available ??? |
Bob@DAE
Now that the porn horns are supposed to be available, i can see on P.A.P. website that they are available complete ready build.
Can someone tell me if there is a passive Xover in the cabinet or is it build to be bi-amplified. |
unclejam
Young Croc Joined: 14 January 2006 Location: United States Status: Offline Points: 525 |
bi amped cross over points are given too
