  New Posts New Posts RSS Feed - Precision Devices PD1845-1N - Any Feedback?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: Precision Devices PD1845-1N - Any Feedback?
    Posted: 10 February 2026 at 3:40pm
Thiele Small Parameters
Fs      34.1 Hz
Qes     0.333
Qts     0.324
Vas     179.04 Litres
BL       26.424
Unfortunately BL < 30, means I would never buy it, but I have heard good things, from others.
Edited by levyte357- - 10 February 2026 at 3:48pm
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2026 at 9:31am
the 2n is a similar story :( lively driver sounds nice easy to run , when start to really push the sub , the 52 was hands down better, (ass scoop and sam pbs scoop for ref)  , know 3 people with the 2n who have had issues when pushing them , all only used 50s before with no issues  :( Ouch
Edited by paulus - 11 February 2026 at 10:20am
TRENDSETTER SOUND SYSTEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2026 at 3:58pm
Yeah, simple comparison of 4-5x of the TS parameters, told me the story, straight away.
Just can't comprehend, how PD went from no compromise drivers, like the 50/51/52, to this..
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2026 at 4:43pm
Because its likely more aimed at touring solutions compared to scoops.
And no compromises means more expensive..
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2026 at 5:45pm
Much longer winding on the 1845 means it will be cleaner when pushed,  the 1850/51/52 might sound louder but i bet if you analysed it the 1845 will be more linear than the 1850.
Its more optimized for reflex as thats what 90% of the market wants,  the diy horn / scoop market is not that big really and they already have products for that.  There is no such thing as "no compromises" its just different balances of compromises optimized for different applications and different markets.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2026 at 8:30pm
Far from every new driver put out there, is aimed for the small scoop society.
Linear is easyer to work with = R&D gets cheaper for the manufacture, so they earn more money on the end user.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2026 at 10:57pm
IIRC, PA crews were using the 18sound 18NLW9601, for years, while Scoopists were raving about PD Scoop drivers.
Turns out, in compatible Scoops, with the sufficient power input, the 18nlw9601, is pretty much the King of 18" Scoop drivers.
Sure it wasn't designed for Scoops, but it illustrates, a high BL driver with right Qes/Qts, Xmax >=12mm, will excel in PA, as well as DIY cabs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2026 at 8:12am
Raising the motor strength means more neo in this case. Which means a higher price (definately with current prices).
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2026 at 8:27am
I've owned these drivers previously, and only sold them due to lack of use, during Covid.
Have to say, these are one of the few items in life, that do what they say on the tin, and is quite easy not to care about the price, when you see/hear what they can do.
A bit like a 2015 Mercedes C63 AMG.. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2026 at 8:59am
That can be for you, but thats not the mindset of most (definately not pro manufacturers).
Besides, the 2160-1N should do the job in that case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2026 at 11:17am
all I know is I used to run the b&csw115 and that is a different story compared to the new neo  offerings from PD, the sw115  is an absolute beast  of a driver Clap
