  New Posts New Posts RSS Feed - Proud owner of mini turbo scoop
Jamo supa powa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamo supa powa Quote  Post ReplyReply Direct Link To This Post Topic: Proud owner of mini turbo scoop
    Posted: 24 November 2006 at 3:57pm
i am the proud owner of 8 of those turbo scoops built and designed by mr ultimate in the west mids toppa top bassbox builder dis side of europe and believe me they sound how they look got rid of fane xb's and all now pd loaded ,stand to close and they stop you breath Ha Ha !!!!!!!!!!! check ebay for contacts peace.
J S P 1
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2006 at 8:19am
pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamo supa powa Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2006 at 2:17pm
check ebay  under bass bins also check toxic
J S P 1
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2006 at 2:36am
i think he means this chap.
jsp, could you explain what a mini turbo scoop is please?
james.
mardy hippy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamo supa powa Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2006 at 9:46am
the mini turbo scoop is a scaled down version of the rear horn loaded scoop with internal adjustments calibrated with a db meter and spectrum analyser in order to give you the close if not same high powererd deep bassline as the larger version of the box at a given frequency ie 30 40 50 hertz .Its a tuff box and can be nearly lifted up by one man check mr ultimate in west mids for more info he's good
J S P 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2006 at 5:07pm
most people here build their own boxes, but i'm sure that info will be of use to someone. i get the impression he'll take on whatever you need.
regarding scoops, i find the taller bins easy to get in and out of the van as i can rock them in and flip them so the weight is at the bottom at the same time, a one man job. heavy stubby things are a two man lift for me, my spine has suffered from this hobby and has aged prematurely...
anyway, some pictures of your little ones would be nice.
james.
mardy hippy.
Insomnia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2006 at 1:15pm
i read somewhere before- it hink a mykey post ,
that the Micro scoops that guy builds are just cut down Fane designs
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2006 at 10:25am
Congratulations mate, U sound well happy with them.
Done the same thing, outed my XBs & got PD & Void instead.
Checked him already, have to agree, he is good. Will be collecting my order from him very soon. He will reads this.
Jamo supa powa, did you go for the 15'' or 18'' version ?
Edited by Tekasis - 29 November 2006 at 6:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamo supa powa Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2006 at 9:02am
GOT THE 18" VERSION BIGGER THE VENUE BETTER THE SOUND
Edited by Jamo supa powa - 10 December 2006 at 9:03am
J S P 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2006 at 9:24am
True JSP.
I'll be trying the Void V-18 1000, PD186 & PD1850 in mine soon when I pop up there to see what I'm finally going to go with. I wonder what the PD neo 18'' would be like in them or any other Neo 18'' driver actually.
We tried the 18'' Volt driver in one last time but it wouldn't fit (rear chamber board too near)
I wanted to test them with my JTS pre-amp but it's in for service/upgrade at the moment. (It can play a bit lower then them mixers, you get me)
'Njoy them.
Laterz.
Edited by Tekasis - 10 December 2006 at 12:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2007 at 5:53pm
JSP how's them cabs going ?
You rock down any where with them yet ?
Be up there this coming w/end I hope, as mine are finally finished. Will be bringing a couple different drivers with me to see what this scoop can really do & If they can drop as good as they look.
Catch up with you & the guys soon.
They look so criss loaded with the PDs...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2007 at 12:51am
4 of these should give us what we want.
Conclusion:
PD1850 run tings.
V18-1000 let me down big time!!! That's why it's parked up to one side.
Edited by Tekasis - 07 January 2007 at 9:27pm
