Punisher Horn build |
Post Reply | Page 123> |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 625 |
Posted: 20 September 2004 at 1:37pm |
Hello guys, Check the following design: http://www.speakerstore.nl/index.php?show=tekening&const ructieID=21&sel_lang=nl You can see pictures of the prototype here: http://www.tweakers.net/gallery/112204/fotoalbum/?MapID=3585 We played a test cd with some strong bass, one time the whole cabinet moved more than an inch back due to the pressure generated at te front! The Punisher was louder that the BR-118 loaded with 18Sound 18LW-1400. One Punisher could keep up with the two EV tops (Punisher playing 45-80Hz) We used a RAM BUX3.4 on the sub delivering a full 1700W (clip leds on sometimes) at the 12 inch Ciare driver (4 ohm variant) The Ciare did seem to like some more... I take your advise serious Rog, we drive them loud until we smell the coils burning (too bad this didn't happen ;-) Best regards, Walt |
whitehousejamie
Young Croc Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
Can you cross it over at more than 80hz? |
Contour
Yes, this is possible they run up to 150Hz or even higher! We found them best sounding crossing at 80 or 100Hz. They sound very deep for a single compact hornsub they are only 285 litres! Best regards, Walt |
Rog
New Member Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Hi, Pro Audio Parts sells all Ciare drivers including the 12.00SW used in the Punisher Horn. Rog. |
Contour
An inportant EAW designer gave this comment on the Punisher horn (see EAW forum): The Ciare part is quite good for a horn load - high Bl and strong cone. Would benefit from a triple-roll type surround found on other Ciare designs thouigh. Best regards, Walt |
PoteirosCorp
Registered User Joined: 31 August 2004 Status: Offline Points: 178 |
Newbie here. Hey Contour, do you know an alternative driver (on DAS, BEYMA or EMINENCE, it´s not for the price, it´s just I´m from Mexico and this are the easiest to get here) for that punisher Thanks for the input ---------------------- |
davey t
Young Croc Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
Looks a hell of a lot like a single driver version of a LAB horn. Why don't you try an Eminence LAB12 in there? seems like an obvious answer. I guess the Ciare driver is stronger tho?
loophole
Registered User Joined: 02 March 2004 Status: Offline Points: 469 |
or some nice ciare driver in a LAB?
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
The LAB sub won't take speakers with higher BL than the LAB12. In fact, Tom Danley LOWERED the speced BL for the driver after some experiments (The LAB12 drivers was specifically made for that LAB sub and the specs were defined for exactly that horn....). That means the original driver had too much BL and it wasn't even next to 20... The Ciare can be a very good horn driver, as long as the horn is 'optimized' for it. The Punisher would be I guess.... |
loophole
sorry, yeah i know you can't just whack any old driver in a horn and expect it to work great, was just a bit of excited speculation...
when you say 'not even next to 20' i assume you mean it was higher... interesting that the lab needs a driver of such (relatively) high compliance given the length of the horn. what factor counters this relatively looseness of suspension in the driver? is it that it only produces subbass frequencies and can afford to be a little slower? please explain some more :) |
Timber_MG
Registered User Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
What many people forget when looking at the BL figure, is to see it in
relation to Re. Motor strength is often said to be BL/sqrt(Re), which
puts many 4 Ohm drivers in a different light than their 8 Ohm
counterparts. Otherwise everybody would be using 16 Ohm drivers.
nightline
Registered User Joined: 28 February 2004 Location: Netherlands Status: Offline Points: 70 |
Have a look at the Beyma 12 Xmax speaker, this one maybe usefull.
Kind regards
Jack |
