  New Posts New Posts RSS Feed - Punisher Horn build
Punisher Horn build
loophole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2004 at 11:48pm
ugh (again!) i don't know what i was talking about, i for some reason read BL as Qts - once again my question is no longer relevant. dunno why i keep on doing this these days.... too much beer most likely...
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2004 at 12:44am
No, I meant the BL is way below 20.
flashy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flashy Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2004 at 10:08pm
hi,does anyone have any specs on the punisher horn.How does it compare with other horns interms of efficiency eg the hd15,the 186.
The punisher has a fairly long path ,Rog would you use such a horn in long throw application and in situations where high spl is needed eg outdoors.
I am very interested in the design and I am just wondering if there is anyone who can offer some critique for or against the design.
Thanks.
roger dan
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 5:15am
check out the forum  -   like to see ground-plane of prototype and find out how that Ciare is holding up
"if" typed correct link then will lead to some graphs (assume predictions)
http:/www.speakerstore.nl/forum/viewtopic.php?t=36
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 7:31am
freddy it almost worked-when u click the link its wrong tho
http://www.speakerstore.nl/forum/viewtopic.php?t=36
Looks like AJ horn simulation.
Note the high cutoff. Efficient High F3 subhorn,as i expected due to HIGH bl 12" ! This isnt a 'single driver labhorn'
This is completely different :-) 40hz is ~ -10db
at the end,some one asked about the lab12 on it,probably wont work. Lab 12- low Bl,low compression ratio,short horn
Ciare- high BL high compression ratio,long horn
the 1kw power handling could be handy-aslong as power compression isnt 9db anyway
Cheers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 7:39am
I dont know about the XMAX beyma 12 but the LX60 looks similar.
+ they list the power compression figure
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 7:43am
wow check out the driver search utility on that site-you can easily find drivers of similar spec!
http://www.speakerstore.nl/index.php?show=speaker
Bl
Vas
Power
Cost
Qts
Diameter
Brand!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 7:56am
My guesstimation.
Looks prety good!!!
Mouth 2700cm^2
Throat ~ 185cm^2
Length ~2.35metre
F3 43 hz
Horn loaded at ~50hz.Aslong as the driver is linear,no problems :-) The Small mouth only drops efficiency slightly.The only thing id do,is fold it S style so that the driver is easily accessable eg-
Cheers!
my style
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 2:25pm
The LAB horn isn't what I would call 'short'. It is rather long....
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 2:43pm
Oops i missed the all important shortER part!
the labhorns 2.8metres long from memory
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 2:59pm
hey mike
how come sim for Punisher in McBean showed diff (higher) SPL than one (AJ?) by Frederik?  - were  both for 2.83vrms?   seems lilke  prototype used 4 ohm ciare
S fold be nice to load driver without screaming! - how would folding change box aspect for ~fixed bulk? -
would  V-wedge throat in S-fold work better than V ramps  at very top of response?
best wishes
Forum prediction in August http://home.earthlink.net/~buddhaboy2/PH.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2004 at 1:23am
Il check up if i used 8ohm or what :-) mine was jsut a guesstimation of it anyway.
The bulk wont change-the only issue perhaps-is having a Vrc which is too large-because this driver only watns ~20-40litres,and with a big wide horn i may have too much behind it,so partition required,which means waste-or i could minimise the width more,thereby making the horn taller,but not wasting any space !
Thats why the Jbl 15" etc enjoy the S fold-often times they require the large Vrc 60L + anyway so no volume is wasted.
The punisher horn has a V wedge throat-but those partitions minimise the Vtc maximising top end-but by that time the horn width + panel resonance are coming into play anyway
