Punisher II |
Page <123> |
| Author | ||
Contour
Posted: 25 May 2005 at 5:07pm |
Thank you for the picture! Very nice to hear you are happy with the design. You are using front loaded cabinets for the mid/high section. In that case it is best to delay these top cabinet with 2.3 metres so that the sound from the Punisher and tops arrives at your ear at the same time. In that case the efficiency in the crossover range is optimal. I am working on a cut list for all panels of the Punisher II. That should be helpful in the construction proces. What do you mean with CAD plans? The construction plans at: http://www.speakerstore.nl/index.php?l=en&pg=11&p=sp &c=21&prjID= are already changed. These are the plans for the Punisher II. Best regards, Walt |
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 25 May 2005 at 5:22pm |
I think he made CAD plans that help him cut every panel to the ideal dimension like those on the selenium website. |
efreak
Posted: 25 May 2005 at 6:42pm |
Thank you for your kind words and help Walt. By cad i mean a cut/angle for each board which is really helpfull. If you will have a cut sheet for the punishers II then i will wait and only cut my sides, top & bottom, and baffle for now just to have some of the boards ready since they will remain the same. Also i will purchase a driverack soon to handle the delay as you speak of.. |
tb_mike
Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Posted: 25 May 2005 at 8:20pm |
Walt: Youl be aware that I agree with your design idea with the punisher.
What is your opinion of the heating effect in the small rear chamber? Is it substantial or not worrying? Im interested in any papers on this subject. Also im interested in the subsonic filtering action of the sealed rear chamber-and 2HD caused by its tiny volume http://www.woodartistry.com/linkwitzlab/images/graphics/ai r-distortn.gif Cheers |
Mircea Bartic
Posted: 28 May 2005 at 5:58pm |
have you ever used the 8 ohm version of the ciare driver or only the 4 ohm? I don't have T/S for the 4 ohm version, are they the same except, re, le, Bl
I don't know which one I can get my hands on, here in Romania (if I can
tb_mike
Posted: 29 May 2005 at 1:27am |
I bet,that theres no audible difference. Be aware that BL depends on Re,so it will appear different,but it must be the same because the horn is exactly the same,and BL affects the horn alot. |
Mircea Bartic
Posted: 29 May 2005 at 4:14am |
I am aware of certain parameters being automaticly different ,
tb_mike
Posted: 29 May 2005 at 10:01pm |
Obviously Re and Le are different(double or half),but that matters little to the horn. I cant remember how BL changes with differing impedence of voice coil...simply because the drivers I see are generally one or the other |
Mircea Bartic
Posted: 30 May 2005 at 4:44am |
does anybody have the T/S for trhe 4 ohm version of ciare 12.00SW so I can simulate the two and answer the question myself?
Contour
Posted: 30 May 2005 at 7:41am |
You can find the T/S for the 4 ohm version over here: http://www.xs4all.nl/~hofmanpa/index.html Unfortunatly this site doesn't allow for direct linking so you have to look in the speaker section yourself. There will be very small changes in response but you can say both 4 and 8 ohm version give about the same result. So far I have only heard the 4 ohm version. Best regards, Walt |
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 5992 |
Posted: 30 May 2005 at 8:01pm |
BL is a red herring. The correct formula for comparing woofer drive force is BL^2/Re |
djk
Contour
Posted: 31 May 2005 at 5:20am |
The Punisher II cutsheet is ready, you can find it as a Word document at: ATTENTION: the measurement on panel 9 should be 27.47cm! Best regards, Walt Edited by Contour |
Page <123> |
