  New Posts New Posts RSS Feed - Punishers blew away our old 18" reflexs
Lyndon A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Topic: Punishers blew away our old 18" reflexs
    Posted: 12 December 2005 at 10:08am
We worked really hard the last week to get the punisher ready for sat night, working into the early hours of the morning.  The result though, was by far worth it!!!  We had our old pair of OHM 18" running about 400w each, and a single punisher at about 800w.
The Punisher was easily a lot bassier than the two reflexs, probably double.  The sound was a lot more intense too, it's hard to explain!  We were rattling the floor and roof of a small 50 capacity skittle alley.
Now to make about 7 more
We would have run the punisher and other bins harder, but we were lacking top for once (see other thread).
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 10:14am
How well does the single Punisher perform? What amp did you run it with? And what crossover points etc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 12:18pm
I'm guessing it all depends how large a venue you want to fill.  I was high passing at 40Hz, and to me it didn't miss anything in the bass department, tested with techno and dnb.  It was tested on the actual night, very little time for sound checks.
I had one of our 3G amps bridged into it, so could have given it close to 1500 watts.
As the setup time was so small, and I'm running it with 12" mids it was running 40Hz to 120Hz.  Over time I'll be playing with those values.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 12:31pm
I would really like to try a pair, but not sure who could build them properly for me / how much it's going to cost.
Currently using 4 stacks of EV MT2, but want to cut the weight and size down a bit.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 12:47pm
Damn, I can't wait for my P-audio SD-12's to arrive , so I can start bulding my own 4 punishers
Ex Nexus_3
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 1:05pm
Quote but not sure who could build them properly for me
Try loophole on SJ.  He's done some very nice ones for other people first and now he knows what it'll take, could prob give you an accurate quote
chilli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chilli Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 2:18pm
or ask agentried from on here, his mate marcus is a bit handy with a bit of old ply... reckoned the punisher would be a piece of piss after the wsx.
loophole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 3:58pm
ahh jamie you should have got in touch with me a fortnight ago! im building 8 this month, but ive just got all the ply cut :(
im at uni now so building periods are a bit intermittent, but let me know if you still want some come april-ish
i think ive seen pictures of 'marcus's work (was it him building that huge batch of punishers fairly recently?), i imagine he'd be an equally good, if not better, alternative ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2005 at 4:21pm
I'm redesigning the plans so that all all the internal panels slot into routed side panels.  The first one was a nightmare,spent most of the time thinking which bits to assemble, how and when.
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2005 at 4:27am
do it!! it's the way forwards... plus you have the added advantage that if you
make up templates to cut nearly everything out you can virtually production
line the little blighters (when i've finished my martins etc...). have you got
any piccies of your punisher build flipside?
james.
mardy hippy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyndon A Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2005 at 10:20am
Yep, we got lots of photos!
http://flipsidevibe.com/forum/forum/forum_posts.asp?TID=24 &PN=1&TPN=4
Theres some more on previous pages too on that forum.  You can see how we did the access panels, thought that was the best way.  A lot more space to get your hands in without any battens.
I'll start on them plans over the xmas holidays, need to ask the wood cutters how much pre routed panels on theri CNC router wil cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2005 at 10:39am
 Excuse me for being stupid,but what size driver do these punisher horns take? hard to make it out from the photos.thanks.
