  New Posts New Posts RSS Feed - Push pull sub bass cabs
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2005 at 8:37am
Sounds to me like there is some confusion between push-pull using two drivers in a double cabinet but one reversed to cancel non-linearities in the motor and isobarik compound loading (two drivers stuck together, usually face to face).
The former will perform like a normal twin driver cabinet but benefit from some reduction in distortion.  The latter roughly behaves as one driver with a stronger motor, lower resonance and is described above by LunchieTey.
Sorry for the spam if nobody was actually confused on this!!!
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2005 at 8:44am
I was on my way to post the exact same thing
it seems there is indeed a confusion between theese tipes of loading
Ex Nexus_3
