  New Posts New Posts RSS Feed - RCF ESW1018
RCF ESW1018
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 31 December 2006 at 3:16pm
Originally posted by specialjustin specialjustin wrote:
"Maybe a PD186, 18PZB46, L18P300 could deepenize it."
I just think the right driver in the right box is the best way, the 1018 is a budget box anyway were about a grand a pair iirc.
Yeah, but the right driver doesn't sound all that in the box; Box is already built, so have to make the best of a bad situation.
Authentic Martin WSX shipped with a 600W L18P300, put a V18-1000 in there, and it blows original WSX's away..
Same principal here... Be a shame to waste all that workmanship and ply
on 2x 18 subs that dont play sub.
djchristian28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djchristian28 Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2007 at 7:34am
uuh , my english not good ...
the box are good? or bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote djchristian28 Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2007 at 7:10am
there aare finish
there drived by a 1200w 8ohms per HP
and ... very good kick!!! good SPL
Xmax extreme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xmax extreme Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2007 at 10:03am
maybe it would be better to use  the WinISD for this design,
just a question? what would be its port length?  from the plan,do i need to include the length behind the driver? and noticed that they have different area to that of the port under the driver....
Post Options Post Options   Thanks (0) Thanks(0)   Quote djchristian28 Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2007 at 3:58am
not understand sorry
i just know :
the F3 is to 38hz
the big kick is between 63 to 80hz
the SPL continu is 133-134db(1.2kw) and maxi is up to 136db/1m(2kw)
the sound is very good for techno and reaggae dub electro...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xmax extreme Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2007 at 1:10am
ok got it mate, pretty good for techno music and hard dance
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2007 at 2:37pm
is it a good sub for dub music?
specialjustin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote specialjustin Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2007 at 6:48pm
"is it a good sub for dub music?"
I would say no, but some people liked them playin dub and the like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2007 at 7:54pm
Currently, nothing touches scoop for dub music. Folded horn like WSX or SL36 with "right" driver do come close, and are used in JA.
dariuzzo26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2009 at 8:21pm
i have 2 rcf l18p300 and i seek the best scoop for that driver..help me please..i play dub music and now i use that driver in a g-sub but.....CryCry..i need a big scoop kick..help me bye bye
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2009 at 8:37pm
hi dario,
rcf 1088 is no properly a scoop...not a real horn cabs, however it reach 200 hz, so if you have already a mid bass cab like gsub should be better build a fullsize scoop with proper driver IMHO. This if you go for a four way,  but if you go for a 3 way should be nice. However put a midbass on top of this cab IMO is not efficient.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2009 at 3:44pm
thank's bitzo now i have a 4 way and i have intention of aquistare others two sub-woofer for my system if I find the plan that I try...you do not have a plan to advise to me with 60 hz of cut??I know that you are much Bravo.
