RCF LF18N401 in 1850 or 186? |
Page <123 |
mylesound
Posted: 02 April 2008 at 8:17pm |
Noob question, sorry might be common sence but,
using 6 1850s, 3 on each side of a stage, to get my tops up high enough i will have to put all 3 on their sides. i will not be able to couple the mouth's of the horn. will i get the same cut off rate as if it was stand alone? or will i be able to go alittle bit deeper? |
noobsound
Joined: 28 March 2008 Location: Romania Status: Offline Points: 67 |
Posted: 02 April 2008 at 8:49pm |
yeah i guess it will go lower as iff u would use a single one.
u could try and stack 2 on theyr side as in the vid shown above and on top of them u could put the 3'th sub standing straight.. this way u will have the same hight.I saw scoops stacked like this i guess it would work for 1850 too
mylesound
Posted: 03 April 2008 at 5:20pm |
sorry my friends 50hz is just not low enough for me.
when im not doing live sound im dj'ing soca, dancehall, hiphop so im going to continue to look around at some other plans that can get me into the 40's pref 30's if possible. or might just scale up my Gsub stack |
Jake_Fielder
Joined: 08 October 2007 Status: Offline Points: 4236 |
Posted: 07 April 2008 at 8:40am |
The horn length for an 1850 is not long enough to support frequencys below about 45Hz, no matter how big the stack is, if you're after a horn that drops really low then its going to be big, and your going to need alot of them! maybe look into ported horns? check out my ported horn in the "new projects section" the horn covers down to 50ish and the port hopefully down to 33/34ish and (80x60x60cm)
Dj Maca Roots
Joined: 13 September 2007 Location: United States Status: Offline Points: 109 |
Posted: 13 December 2008 at 6:34pm |
Its nice to see your photos any ways.
Raspect! |
Can't Stop Jah Music
Page <123 |
