  New Posts New Posts RSS Feed - Round 18" Grilles
Round 18" Grilles
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2015 at 4:37pm
On the grill subject, sorry for my crude drawing, but any make these shape grill just a few bends ,
with resorting to big companys and silly money...as markie said box pan grill , but with some bends in it like the pic
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2015 at 5:05pm
Originally posted by markie markie wrote:
Here's what I don't understand. Round grills are about a fiver each for the cheap ones (that are almost made on tinfoil) or £9.00 for one made of 1.1mm steel. Then theres £3 odd for a set of standard clamps, so that's £8-12 per cabinet. Then you have to mess around with wooden rings to allow for the excursion.
The above cabs have batten already fitted for  a square grill to fully cover the driver. I charge £16.50 max for such a grill which is 1.5mm thick and looks (hopefully) far more professional. For an extra fiver you can even  have it powder coated.
Doesn't seem to make sense to be but then I am biased.
I think for some it's purely the looks of it, show as much wood as possible and that
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2015 at 5:09pm
no ?
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2015 at 7:40am
Circular grills are good for prototypes. If you know that you might change the design later but still want to defeat inquisitive fingers. I'm also considering a hi-fi style cloth front as that can be made to measure in a similar way to the metal grills but is much cheaper.
RC1 Sound System View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RC1 Sound System Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2015 at 7:41pm
I'm sure I've seen speaker grill spacer rings commonly for sale in the car audio world to fix just such a problem.  An off the shelf product you just clamp under the grill to give better clearance from the cone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2015 at 8:55pm
yes yes true rc1 , you can router them out yuself easy enough too
