routed sides |
Post Reply | Page <12 |
Twirl
Registered User Joined: 07 November 2011 Location: South Wales Status: Offline Points: 249 |
A well built butt-jointed cab properly screwed and glued should not fall apart through vibration! However, as Mike pointed out, the more glue-able surface area the better...
I also find rebating speeds up construction and produces a more accurate build.
shagnasty
I rebate folded horns using a 30mm follower and laser cut steel jig, the jig means I don't have to mark out my panels, I just axe up the sheets on a wall saw and them blast out the horn profile, assemble is a peach and it reall makes a nice job.
A cheat is to use a rail mounted festool router and CAD out you sides 1:1 and use the paper as a template, either spray mount it onto the board or make cuts through it with a stanley knife join the dots with a pencil...
ceharden
Both methods are valid. The key thing whether you're using rebates or biscuits, or even just butt joints is to make sure they're tight. Wood glue (PVA based) works best when you have the maximum surface area touching each other and cures with them held tightly together.
An accurately cut and assembled butt jointed cab is probably stronger than one with loose fitting rebates and poorly cut panels. |
Tony Wilkes
Chris's comments above probably cover the whole question.
Tony |
Wrek0ne
Young Croc Joined: 10 February 2011 Location: Cambridge Status: Offline Points: 749 |
Good job my house mate has a Festool 1400 router then!! |
Poll this!
