Safe saturated bass |
Page <12 |
| Author | ||
valve head777
Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1846 |
Posted: 26 August 2025 at 3:26pm |
This is probably the sound you are after. It took years of experimenting to reach this without blowing drivers. I can run 6k plus of this sound.
Pretty much any transistor based distortion will be square wave, doesn't matter if that's before the power amp or by the power amp. Square waves will over heat any driver, even if powered by a fairly low power amp. You find better results if the signal gently turns into a saw tooth wave. Valve amps do this party because of the output transformer saturation and the way the valves clip. Turning any transistor based system into the red to get the sound you want just costs you loads of money in repair and finishes sessions early. However big valve amps also are notorious for finishing sessions early. "Bwoy, dance finish because valve amp a bust again cha!!"
Edited by valve head777 - 26 August 2025 at 4:00pm |
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 29 August 2025 at 1:33pm |
Hi, I have 30 Years Recone experience ...... 30 Years of repairing blown DJ and MI Speakers ......RED MEANS STOP.......VECTORSONICS Auburn, Maine USA
knet94
Joined: 31 March 2008 Location: NW London Status: Offline Points: 1538 |
Posted: 30 August 2025 at 3:26pm |
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 30 August 2025 at 5:00pm |
Does not sound good I agree
valve head777
Posted: 30 August 2025 at 6:57pm |
Many thanks. Its a beautiful diverse world. The distortion in the mid is my phone mic distorting. The bass sounds very close to what I was hearing. Its the bass I was trying to demonstrate.
If you don't like this sound, is it likely you'd enjoy the op's sound given their description of what they do to get the sound they want. Its s very niche thing we try to achieve. Many hated Shaka's set. But many loved it too. Edited by valve head777 - 30 August 2025 at 7:38pm |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Online Points: 8517 |
Posted: 01 September 2025 at 2:53pm |
I mentioned earlier in this thread (and the original), the OP, should only consider advice from people, who have experience of running Scoop Reggae systems, and also bridging amps. Not all amps clip/redline, wholly due to the input signal being too hot, and not all amps square wave and burn voice coils, when they clip. Those with sufficient experience of various drivers, cabs, amps playing Dub Reggae will know this. I'll wheel out, this old chestnut again. (Video filmed by fellow Speaker plans member) Back in the 2013 glory days of Golden Palace Soundcheck, in NE London. Video taken of set I brought, along with some illustrious mates assisting. My Lev .44 Scoops, 3rd outing, loaded with UK made PD1852 prototypes, provided by "Kutty QSS Qualitex", Ren "APS" at the controls. I had heard these drivers in other Scoops, seen the T/S Parameters, so drew up plan, "optimized" for these new drivers. As it was a "sound check", for a while the bass section was powered by pair of bridged QSC RMX 5050s, for a while, single Powersoft K20. Mains supply was 1x leg of 3phase 64A supply, and boy, was it rigid. During certain bass notes, the current draw was approx 34A @ 240V, the engineers amongst you can deduce, the approx peak power going to the subs, at times. Was told the sub that night:
No drivers blown, another sound there, blew drivers trying to keep up. Another example, of when mains supply is right, and cabs, drivers, sub bass pre-amp, knowledgeable engineer, are in harmony. Much of the above, is what OP is looking for, much of it will be un-acceptable to some. ![]() Edited by levyte357- - 01 September 2025 at 3:08pm |
valve head777
Posted: 01 September 2025 at 4:38pm |
![]() Edited by valve head777 - 08 September 2025 at 2:59pm |
Norseman
Joined: 04 March 2013 Location: Torquay Status: Offline Points: 132 |
Posted: 22 September 2025 at 11:14am |
Change the JTS to a s&p with "growl" knob to emulate valve distortion harmonics.
I believe the new sage and also the bass module by JB also have a similar function as does the forthcoming preamp by abzu These are basically overdrive circuits in the preamp. Then adjust amplifier sensitivity downward to accomodatw hot signal. Amplifier amplifies anything coming in by a fixed amount, say 32x for example. So if signal going in hotter and with added harmonic distortion, amp sens can be attenuated to match and allow proper gain stage with optimal signal to noise ratio Josh
Edited by Norseman - 22 September 2025 at 11:14am |
paulus
Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Online Points: 3237 |
Thanks(1)
Posted: 22 September 2025 at 11:49am |
TRENDSETTER SOUND SYSTEM
Page <12 |
