  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  <1 232425
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 7:09am
Originally posted by alehmarques alehmarques wrote:
Yes I did, but it is already on the list of compatible drivers... I mentioned the DS100 because nobody talk about it... there is a hot deal on Bluearan right now (may 2022) only 275GBP 18DS100.
I see, that makes sense Clap
Navanor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Navanor Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2022 at 1:08pm
Hi everybody,
Is the Lavoce SAF184.3 a good choice for a scoop? I'm planning on building 4 of them
Resonant frequencyfS30Hz
Electrical QQES0.34
Mechanical QQMS6.70
Total Q factorQTS0.32
Suspension equivalent air volumeVAS245litres
DC resistanceRE5.8Ω
Minimum impedanceZmin7.2Ω
Voice coil inductanceLE2.1mH
Force factorB·l28T·m
Suspension mechanical resistanceRMS7N·s/m
Suspension mechanical complianceCMS110µm/N
Moving massMMD219.8g
Moving mass (including airload)MMS250g
Surface of the diaphragmSD1225cm²
Effective diaphragm diameterØ39.5cm
Maximum linear excursionXmax± 13mm
Excursion limitXlim± 22.3mm
Displacement volume at XmaxVD1592.5cm³
Efficiencyη₀1.7%
Efficiency bandwidth productEBP88
Cheers,
Nathan
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 11:29am
forget about it, the italian name should not trick you. chinese 100% and to me sounds so bad. never heard this specific unit.
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 2:32pm
Nobody is being tricked by the name. its not a secret where they make their drivers. Second, how can you say it sounds bad if you do not have any experience with the driver?
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 3:20pm
i heard something else that's from them paper looks great but in fact poor chinese driver. someone try to sell it as italian manufacturer, trust me. happy if with this unit they change the mood!
Edited by _Natty_ - 12 February 2024 at 3:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 3:32pm
I have used two of their models currently, both performed as expected. There are even some more in depth reviews of for example the 214.50 on databass. Would not expect any different from the 184.3, if it will do the job in a scoop is another subject.
PS: they are designed in Italy and manufactured in China (just as the advertise), so not your standard cheap China driver.
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2024 at 12:14am
Kid Creole (Mykey) thinks very highly of LaVoce.
