scoops with amps modules? |
UpComingSound
Joined: 21 June 2006 Location: United States Status: Offline Points: 394 |
Topic: scoops with amps modules?Posted: 21 May 2013 at 3:41pm |
powersoft is now selling amp modules for stand alone speakers, do u think scoops will be speakers to turn active ? http://www.powersoft-audio.com/en/products/amp-modules.html
UpComingSound
Posted: 21 May 2013 at 3:43pm |
for 12 15 18 and 21 inch woofers
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 21 May 2013 at 4:34pm |
...active scoop/hog with built in DSP?..... mmmmmmm.....
mini-mad
Posted: 21 May 2013 at 4:35pm |
...daisy chaining just got a whole lot easier....
studio45
Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3881 |
Posted: 21 May 2013 at 5:27pm |
where would you put it? all the air space inside a scoop is active, you can't stick an amp module in the horn path without messing up the expansion, or in the rear chamber without reducing its volume. You'd need a lump sticking out the back of the box and that's not going to look good, or be practical for truck packing.
shagnasty
Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7683 |
Posted: 21 May 2013 at 5:38pm |
most scoop designs have quite an ideal dead space for the module, behind the scooped bit near the bottom...
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 21 May 2013 at 5:41pm |
All the Amp Modules I've seen so far haven't been very big, so providing the power needed is achievable, it could go behind the scoop section whether it be round or staggered straight pieces. It could be mounted within the framework that perhaps supports the curve and an access panel could be made.
Sypa
Joined: 21 February 2013 Location: Croatia Status: Offline Points: 953 |
Posted: 21 May 2013 at 6:30pm |
http://www.highlite.nl/silver.econtent/catalog/highlite/entertainment_products/dap_audio/speakers/touring_series/lt_18hl
Dont know if its relevant but il leave this here. edit:Fail that is a passive one,http://www.finesound.nl/verkoop/product_info.php?products_id=477 Edited by Sypa - 21 May 2013 at 6:34pm |
darrell
Joined: 26 April 2022 Location: Belgium Status: Offline Points: 4 |
Posted: 27 May 2024 at 11:26am |
Very late to this but check out Stakx Solutions.
