  New Posts New Posts RSS Feed - <<:::::: Show off your Funktion-One ::::::>>
 Post Reply Post Reply Page  <1 66676869>
discosucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 4:46pm
So do all the Funktion one users really not use any EQ??
I know its said that the design is meant to be flat but can any design really be flat?
Would love to know if everyone is sticking to the recommendations of using none or are they
eqing the boxes and getting better results .
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 4:51pm
just hadn't thought of that , some time back I was going to put some Martin 215 Mk3 , I just got afew Kitchens and bathrooms to work on so my days are short , since I alsohave a 3year old girl in the house that needs to see Baba at home , spring's here soon ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 5:04pm
All of the serious an good ones I know of use EQ on the system whether to correct for rooms or arraying
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 6:12pm
do they eq each driver in the boxes or is a general eq?
I'm a total novice and don't really understand where eq should be applied for what
ever application its being used .
My guess would be that you use eq on each pass when getting boxes lined up with delay , and then use
a general eq over the whole system to sort out rooms and array?
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 6:36pm
You have eq for box correction, on each output - then you have a 'full range' eq for room correction and your tastes.
So a speaker preset would have the settings only applied to it's specific output.
Funktion One don't need loudspeaker eq they say, but you still have to compensate for the room anomalies - they're only speakers, no fairy dust inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 8:08pm
Yea thats what I do with my system and was hoping it was right LOL
one more question , I have heard them say a lot about the systems being very coherent
So to get great coherent systems you have to get tight time alignment right?
but how do they get the systems time aligned tightly with out eq .In any of the tutorials i have watched or read on time alignment using software's like smaart each speaker needs some bit of eq to get them to mach up the best the can .
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2015 at 8:19pm
Ohh, i dont EQ, its all beeing done on the LMS.. ;)
An EQ wont help much with time aligning..
You need to set delays, possibly polarity changes of 180° or lower, allpass filters help to apply phase changes to a certain bandwidth, notch filters can reduce room or cabs resonances etc. etc.
take it as BS, any system needs correction according to circumstances ;)
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2015 at 4:06pm
Far-canada
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2015 at 5:18pm
oh wow...
that's really something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2015 at 7:49pm
but wouldnt you need to eq thee pass to make it flat for alignment?
Audiowall Systems View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audiowall Systems Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2015 at 7:46pm
We run Funktion-One Res5 and F121 with no EQ. The processor has no PEQ settings at all for the outputs. Just time alignment and crossover filters.
We don't run any graphic on the main output either. When we first started using Funktion-One rigs, we used to take a BSS FCS-960 31-band Graphic to correct for the room acoustics as you normally would with any system. I found I didn't need to use the graphic and these days I don't even bother taking a graphic for the FOH rig if we are using the Funktion-One.
Resolution 5 have very tightly controlled dispersion of 25°H x 20°V, so if the box's are pointing at the audience (with the help of the tilt boards) then the direct to reflected sound ratio is very good. As the sound is not exciting the room so much and you are getting much more direct sound, so you don't need to EQ for the room.
We also have a Martin Wavefront rig and that sounds great with the manufacturers reccomended PEQ settings, I have tried a similar EQ on the R5 to see if it sounded good and it sounded distorted. As soon as I applied a boost in the top end frequencies, I could hear a smearing of the frequencies across the whole frequency band that the EQ was effecting. The Funktion-One rig sounds best without any EQ on the processor outputs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2015 at 9:56pm
Interesting !
I follow you guys in facebook and see you do lots of big stuff so I take your word as people who know what your talking about :)
