  New Posts New Posts RSS Feed - SHOW US WHAT YOUR MINI SUB RIG CAN DO
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 8:33pm
I'm quite happy playing ANYTHING. I know my subs won't match mini scoops for output, but I'm confident in the quality department.
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 9:53pm
What do you have in mind? those cube subs you built?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 10:01pm
Gotta respect that point of view. Clap
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 10:24pm
Yes, single 18" reflex. Just a question of how many I am allowed to bring...
My twin 8+ 1" tops too, so there pretty tiny
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 10:44pm
So let me get this right, above bass is a standard system and all bass must be 'mini'?
Reason being Tony ASS rig has mini scoops but above is not what I would call mini
bit confusing at the moment
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 10:44pm
CSG, i use the BMS components in most of my boxes, but i have never made a subwoofer using any of their 18 inch drivers.
This is mainly because in any simulation i have done they had at least 3db less output aginst pretty much any other decent 18 inch driver.
Now my question for is. Are the sensitivity numbers on the BMS big boys somehow rated very conservatively so the results are not that good, or they are really a bot low on output?
Have you compared your subs with some other comparable subs with some of the known suspects like the TBX100?
tomr_29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomr_29 Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2013 at 11:26pm
 "Are the sensitivity numbers on the BMS big boys somehow rated very conservatively"
Turned around you could also ask if the sensitivity measurements given by a lot of manufacturers are a little optimistic... A bit like the values given for xmax.
I'd be very interested to hear some of the smaller subs compared as I regularly use a pair of Q15s for smaller gigs. I also have a dual 18" design I've been working on which is based on Tony W's work with his Q-series (in that it uses assisted alignment). They will be using the BMS 18S450. I'd be happy to bring one along to a test-out sometime in the new year once they're built. Not sure whether they qualify as 'small' though; 1000H x 638W x 700D for 2 x 18"
Proper capitalisation is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse.
www.facebook.com/tremoracoustics
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2013 at 12:12am
When I was designing those subs, my prime considerations were sound quality, perceived throw ( there get used a lot outdoors at large events and musicality. One of my pet hates is one note droney bass.
I auditioned various drivers, but for me the 18S430v2 had the best balance of factors.i am quite sure there are higher output options, but rinsing every last DB from a rig is not what I am about, and I have the luxuries of having plenty of power in my racks, plenty of subs when needed and working In venues that have effectively unlimited power for my needs. My Christmas install for instance has 0.8MW of gen plant for instance.
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2013 at 7:50am
Exactly my thoughts as well although I have to say that I hope that the source material is better recorded than a lot of the stuff I have heard over the last few years, of any genre.
By the way Ray you sure you don't have a secret passion for C&W as your the only one that ever mentions it on SP. :)
Tony
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2013 at 2:57pm
My 12" loves this
http://youtu.be/I1gewNVv1UY
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2013 at 3:23pm
Tony
http://forum.speakerplans.com/calling-out-the-big-boys_topic14624.html
Originally posted by Rog Rog wrote:
I don't think people realise what and how systems like Irration play there bass. Lets just say its not country and western to 20 people on a sunday afternoon like most PA rental compaines have to do most of the time.
That's where I got it from...   LOL
Edited by levyte357- - 08 December 2013 at 3:24pm
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2013 at 4:06pm
Originally posted by Meat Meat wrote:
If you can fit your mini in a mini then its a mini.
I once got an 18U flightcase in my 1275GT (it had a one of those Webasto slideback sunroof thingys).
Slightly off topic, but still trivial enough to mention...
