SMT 212 w/ Build pics. |
Page <1 234 |
djtecthreat
Joined: 14 July 2008 Location: MA (USA) Status: Offline Points: 119 |
Posted: 02 November 2008 at 11:01pm |
Will do waffles..
Where did you get your ply from? I cant find a good source for the 15MM ply? I can get good ply in 1/2" and 3/4" but not 5/8". -Jim |
wafflesomd
Joined: 21 September 2007 Status: Offline Points: 811 |
Posted: 03 November 2008 at 12:00am |
Just use 3/4" ply. The thickness won't affect the build.
Also, there's an error in the plans. Piece F should not be 388mm in depth. IDK how long it should be. I would suggest cutting it to 388, then cut it down accordingly when you start to assemble the cabinet. |
djtecthreat
Posted: 03 November 2008 at 12:56am |
I was planning on using 3/4" Mostly because it's a bit stronger, just wasn't sure if it would throw the plans out too much.
Did you build yours with 3/4"? |
wafflesomd
Posted: 03 November 2008 at 1:13am |
Yup.
Page <1 234 |
