  New Posts New Posts RSS Feed - Some Bass Horns
Some Bass Horns
 Post Reply Post Reply Page  123 15>
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Topic: Some Bass Horns
    Posted: 12 January 2008 at 1:12pm
Heres some plans for horns everybody's always looking for.
The Peavy will be better than the B36.
All of these cabs will get raped next to either the 186 or the 1850[off course]
The B36 is a piece of sh*t because the baffle the 18 mounts to is so short. You will always have a problem to fit a woofer.
So, All of these are bitches to build at the end of the day. You can just as well build one of Rog's horns an be better off.
Cerwin B36:
img249/6360/b36bc3.jpg
Cerwin AG36
img300/9536/ag36ge3.jpg
Peavy DTH118B
img300/4467/peavydth118bra5.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 2:05pm
The Dynacord F 12 CWH.
Use same component options as the MT 122
img518/4885/dynacordf12cwhbm2.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 10:02am
Originally posted by Three-Bee Three-Bee wrote:
Look at this
Blue Line: SL-36 with SD18
Grey Line: 1850Horn with SD18
both modeled 1/8 space
img168/8291/compje9.jpg
AND the SD18 will just squeeze in.
img144/3865/slsd18zv9.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 10:12am
1850 Horn/SL-36 Size external comparison
img140/5056/12345tg7.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 10:25am
B36 loaded with P-Audio E18-600A.
Blue: 4 bins
Grey: single bin
img181/3796/b36uy5.jpg
suiluj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 12:01pm
  Great job three-beeClap, could you please post the input data for the B36 and SL36
Or please do me a favor,  please load this driver for me, I would like to know how this driver perform in B36 or in SL36.
here's the specs of my driver.
Fs: 33.55 Hz                      Pe: 500 watts rms continous
Qes: 0.285                        no: 3.086%
Qts:  0.257
Qms: 2.649
Bl: 29.2 Tm
Vas:  241.1 liters
Cms: 93.72 um/N
Mms: 240.1 grms
Rms: 19.11 kg/s
Xmax: 5 mm
Xmech: 7.5 mm
Dia: 414mm
Sd:1350 sq.cm
Vd:0.673 liters
thanks in advance for the effort mate
regards
suiluj
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 3:39pm
k, with what u gave me. what driver is it?
blue : sl36
grey : b36
hope it helps.
Build da SL though
img90/9716/24134737yv9.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 3:50pm
Another SL-36 plan
img174/2668/sl36lc4.jpg
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 4:05pm
Wow!! The new world leader in speaker plans is Three-Bee! More...more....VECTORDJ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 5:10pm
The AB-36 drawn from the GIF on their site.
Comparison with SL [in Grey]
img134/8981/absl36jc1.jpg
& it seems as if the SD18 should fit....
img220/5830/ab36sd18wz0.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 5:15pm
This is what happens when you're on leave with a 3G modem....Wacko
I just hope most of the questions about the Cerwin bins you always see on the forum can be answered by this thread. I still don't know how 1850's or Looney's sound though. I do know how the AB36 with its sh*tty 18 sounds. OK for the price. Would like to hear it with a decent 18" though.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2008 at 5:59pm
Here you have the AB, SL and B 36's all with P-Audio E18-600A's. Looks good. The SD18 models The same, just louder.
All in all, all of them will work nicely when you use enough. Still too much hassle to make something fit in the B-36.
img175/9645/cerwinbassrm5.jpg
