Something to do with your Celestions! |
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Posted: 01 August 2008 at 8:49pm |
Gentlemen,
Many of you have probably seen these, but I will post them up for the benefit of those not on FSP. These designs were wholly designed by Simon of FSP who has designed and built and tested them. I've mentioned them in a few threads so I thought I'd post them. They are a good use for that stack of Celestions that you obviously have lying around , and work with other drivers as well. Here: 1x18 bass horn (Celestion HDX) http://freespeakerplans.com/forum/forum_posts.asp?TID=217 C-Bin 1x15 kick bin (Celestion 4080FD) http://freespeakerplans.com/forum/forum_posts.asp?TID=218 folded like a Martin F2B. 1x12 DR mid horn (Celestion TF1225e) http://freespeakerplans.com/forum/forum_posts.asp?TID=219 Please take your time to comment. I have preliminary plans of these in dxf format, they aren't the final optimized versions, but PM me if you really want to have a look, otherwise Simon has put screenshots of the said CAD drawings on, as well as plots. Also, if any of you would mind going down to Dorset with full measuring gear You get the same prize if you go down to Shropshire and look around Robbo's F2Bs. I bid you good day gentlemen, |
Away on extended leave.
