  New Posts New Posts RSS Feed - Sound cards clashing
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Topic: Sound cards clashing
    Posted: 27 January 2010 at 10:12am
Details;
Got 2 of the same model same brand sound cards put in, Sound blaster live CT 4780
with 1 card only in its fine, but with 2 cards in each PCI slot it causes a system conflict n the pc switches off, then i have that serious error screen when it starts again
Windows operating system is XP home
Possible I/O conflict but cant work out how to change it??
also a quick question, if i have 1 soundcard in pci slot 1 and the second in pci slot 3 would this cause the volume to be louder on any of them
any help guys as this is really buggin me!
NiPZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NiPZ Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 2:02pm
Is there an error number or anything displayed or just a window telling you that something went wrong somewhere?
Have you checked to see if you have the latest drivers for your mother board and the cards themselves.
Also it shouldn't affect volumes depending on which PCI slots you have the cards inserted in!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 3:02pm
yep all the latest and correct drivers, cant get as far to check the error code as itll have restarted already
tryin to find out which jumpers on the actual card need to b changed but cant find the schematic!
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 3:13pm
Are you sure 2x of those cards is a valuable configuration?
I would google for that card before anything else.
I know all about IRQs, and data ports, and  BIOS PCI slot configs, but if the drivers don't support your configuration, you're stuffed.
Is there a reason you need 2x sound cards?
Another possibility is installing 1st card, and modify IRQ & I/O addresses/resources from default.
That way, 2nd card installation "may" install to default settings, and not conflict with first.
Edited by levyte357 - 27 January 2010 at 3:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 3:43pm
Lev i use 2 of them so that the outs will go into seperate channels in the mixer, drivers didnt need installing as windows picked them up staright away and they were ready to use
"Another possibility is installing 1st card, and modify IRQ & I/O addresses/resources from default." this sounds like it could work as when i had just the 1 card in it was fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 4:20pm
Don't forget those cards are 12 years old. Dead
EDIT:If you get a modern 5.1 £20 sound card it will "probably" have better sound quality, modern drivers that make better use of CPU multimedia instructions, and probably 4-6x  outputs + optical/digital. Confused
http://www.microdirect.co.uk/Home/Product/8462/Terratec-Aureon-5-1-PCI-6-Chan--Digital-in---out
Terratec Aureon 5.1 PCI 6 Chan. Digital in / out soundcard
Terratec
  • Manufacturer: Terratec
  • Manf Code: E3307
  • Quick Code: S006416
  • Availability: In Stock
  • Instore Stock:Click Here
£18.39 inc VAT
£15.65 exc VAT
Edited by levyte357 - 27 January 2010 at 4:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 5:40pm
do you recon id get the cards clashing with these?
will be able to run both simultaneously?
while your at it Lev why is one card louder than the other one, switched the cards around n the problems still there in PCI slot 3 Confused
tallmike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tallmike Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 5:59pm
thought you lot loved sound (card) clashes?!
If you're dealing with IRQs and ports, your cards are too old! I rember setting them up to play Doom, and so will you Lev!
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 6:03pm
Oh yes I remember all that jazz...
Learnt years ago, bin old cards, and get new stuff, where the  plug and play works... Embarrassed
Get a 5.1 sound with RealTek chipset... Then you get a load of fancy software for doing configs...
Your computer must be old, if you dont have 5.1 HD sound on the motherboard...
My motherboard has it, and I bought it in 2007... LOL
Edited by levyte357 - 27 January 2010 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2010 at 6:05pm
LOLLOL good one LOLLOL
cool ill give it ago
