  New Posts New Posts RSS Feed - Sound Project
Sound Project
Sloth69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sloth69 Quote  Post ReplyReply Direct Link To This Post Topic: Sound Project
    Posted: 27 September 2013 at 12:55pm
Hello to all!
I would like some advice on the right choices ...
I currently have 2x 1850 folded hord
2x hd15 horn
I took the plans and built these speakers a tight squeeze ..
For hd I'm going to put the pd 154 ...
For 1850 I would opt for the P.Audio 18w2000
http://www.eighteensound.com/index.aspx?mainMenu=view_product_simple&pid=306
Among my amps I also 2x peavey CS4000 ...
I thought maybe I could use their 4kw @ 4ohm to greatly increase the W cones ...
I thought then to build 2x es18bph with P.Audio SD18 1700n ...
My concern is to build a balanced sound ..
How could I combine these speakers?
Should I build two more in 1850?
I should make two 186 horn?
Build 15 other hd??
Or build these es18bph with cones 1700w?
Looking at the list of compatible cones I saw that there are also
18NLW9600 who 1800w!
Although in reality as frequencies are not particularly suited as the P.Audio
http://forum.speakerplans.com/drivers-for-1850-186_topic68912.html
So ... how should I proceed with the construction of my sound?
Thank you all!
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2013 at 2:23pm
If you already have 1805s then build two more. Don't get bogged down with all the choice out there, just stick with what you have.
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2013 at 3:48pm
+1. Stick with the 1850s. Don't mismatch several different types of bass bins.
ape3435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ape3435 Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2013 at 3:59pm
+1..and also keep either HDs or ES18, preferably HDs as more punchy in my opinion
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sloth69 Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2013 at 6:00pm
thanks to everyone for the feedback!
For 1850 so I should put P.Audio 18w2000 or 18NLW9600?
How can I make the most of peavey CS4000?
