staiper micro scoop question |
hmaudio
Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3852 |
Topic: staiper micro scoop questionPosted: 28 August 2011 at 3:20pm |
what exactly does this part do?
![]() iv built 4 and iv not put that part on
This account is used by 2 people. |
eltron
Joined: 21 December 2007 Location: Finland Status: Offline Points: 399 |
Posted: 28 August 2011 at 8:35pm |
It forms the throat. Notice the 110 mm measurement on the left!
Look at the super scooper plan for instance, you'll find the so called "dog leg" on it also. Edit: I missed the last part of your post: If you left it out the throat has theoretically moved downwards in the horn (technically to the narrowest point), thus making the back chamber bigger and horn shorter.
Edited by eltron - 28 August 2011 at 8:37pm |
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 28 August 2011 at 9:47pm |
Personally I'm not sure whether it will give you any noticeable difference (to your hearing that is). You could however glue it in there through the speaker cutt out, if you make it in two halves (in the length).
Best regards Johan
hmaudio
Posted: 29 August 2011 at 12:26am |
Thanks for the replies, il get some made up and see if i can hear any difference,
cheers Adam
phildat
Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
Posted: 29 August 2011 at 10:49pm |
Looks like it ensures positive expansion throughout the design.
Its just a ride.
MINTEVENTRESOURCES
Joined: 12 April 2017 Location: USA Status: Offline Points: 59 |
Posted: 01 March 2023 at 5:01pm |
Was there a noticiable difference in performance by adding the dog leg?
Mint Event Resources
stitchie
Posted: 11 June 2024 at 6:04pm |
still got 4 of these built by you HMAudio really good sub cab for a 15" driver
