  New Posts New Posts RSS Feed - t amp ta2400 in parallel mode
davidhodgson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidhodgson Quote  Post ReplyReply Direct Link To This Post Topic: t amp ta2400 in parallel mode
    Posted: 23 August 2009 at 2:39pm
hi
if we put our tamp 2400 in parallel  mode and connect 2 peavey ul18,s (8 oms each) to each speaker output will this be ok .the manual says it runs at 8 ohms in bridge /parallel mode.
obviously this will only be in mono but thats ok for subs.
many tx
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 4:47pm
Originally posted by davidhodgson davidhodgson wrote:
hi
many tx
Parallel mode just means one signal applied to both channels.
This is not a quality sub amp, like qsc, crown, crest, so I would'nt drive it into clipping if you value your speakers. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidhodgson Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 6:15pm
tx for reply
but what ohmage will the amp be running at
in the manual it says 8 ohms bridge mode
the speakers are both 8 ohm cabs so what will the amp see
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 6:46pm
4 ohms per channel.
As far as impedance is concerned its that same as running the amp in stereo mode.  Parallel mode just means splitting the input signal and feeding it to both channels.  Each channel has 2 x 8ohm speakers connected so each channel is seeing 4 ohms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidhodgson Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 10:31pm
tx
sorry for confusion there will be only 1 8 ohm speaker connected per channel
