tapped horn design |
Page <1234 9> |
james folkes
Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
Posted: 31 January 2007 at 11:18am |
william cowan's research is very interesting, we are so very indebted to those who take their time to document this stuff for the good of fellow enthusiasts... what i don't get is why his 60 Hz horn gets worse as you move the driver up the horn? having read danley's white paper and looked at the other commercial tapped horns i thought that the driver in the mouth would not load the upper range of the horn's response, and was accordingly going to try a different position on the mkII giatt...
can anyone hint at what's going on here then? or do i need to make a series of boxes at the different "tappings" and try and measure them all? james. |
mardy hippy.
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 31 January 2007 at 12:25pm |
james, it is acting just as the first version of planar horn
as you move the driver more inside the horn, the mouth becomes to small to sustain the wavelengts involved. with the driver nearer to the horn exit it acts more as a bassreflex design lower down in frequency. everything I said here happens besides the usual problems associated with phasing between the horn output and driver output. |
philpope
Joined: 21 January 2007 Location: United Kingdom Status: Offline Points: 42 |
Posted: 31 January 2007 at 3:27pm |
yeah i don't know why cowans results were bad for the driver being away from the mouth as this is apparently what the danley dts20/pb12 model is.
none of the diy attempts at a tapped horn other than mine have moved the tap away from the horn throat which i think is very important for good results. doing so moves the driver away from a velocity minimum and means you can keep the compression ratio and cabinet volume low at the same time. it will also reduce resonant modes as is done when offsetting drivers in a transmission line. not too sure what varying the compression ratio from 1;1 will do but i think this must be the case in something like the TH215 or the horn wouldn't fit in the cabinet volume. i worked from the assumption that 1;1 compression would give the best bass response and least stress on the cone. will post some measurements from my cabinet as soon as i have some. got some ideas about how the TH112 and outline boxes are folded so might be able to make something along those lines. not found a very suitable 12" driver yet though. Phil |
philpope
Posted: 31 January 2007 at 8:21pm |
there are some interesting photos at
http://srforums.prosoundweb.com/index.php/m/184228/2366/#msg_184228 |
odc04r
Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5469 |
Posted: 01 February 2007 at 5:37am |
I may be completely off base, but I wonder if the classic scoop dip in
response at ~100Hz has anything to do with the dip that can be seen inm
William Cowan's results. I was thinking about it the other day and
maybe a scoop could be considered as a tapped horn with driver located
right at the start of the horn and the front of the driver firing into
a very large last expansion (the room.)
jethrocker
Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Posted: 01 February 2007 at 1:05pm |
odc04r, Moray James started discussion on this over in the scoop forum and we were wondering if the tap horn effect in a scoop might be enhanced by angling the baffle into horn mouth, this would also enlarge mouth area to the size of the front of the whole cab.
philpope
Posted: 01 February 2007 at 6:53pm |
I may well be wrong because I haven't done much research on scoops (because the measurements and sound of most scoops I have seen/heard has been unpromising).
doesn't the back chamber in most scoops act as a low pass filter precisely to minimise the frequency range where horn and DR are interfering. also a scoop doesn't tap into the horn away from the throat end.
Phil
philpope
Posted: 01 February 2007 at 6:58pm |
I'm looking at the picture of the TH215s. can see through the mouth to the back of the cabinet where there is a little wedge splitting the horn into two seperate paths, yeah? what's that white strip on the bottom speaker? is it inside? is it a driver? if so, why can't the same be seen in the top speaker?
![]() Phil
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 02 February 2007 at 8:45am |
i have been working on a sub called "DUBSUB" (scoop) with a 12.75 ft around 3.65 metre horn and is the cats wisker's and scare's the life out of me you can dry your hair from this beast
single 18''
just tested it yesterday in a 3 badminton court sports hall, and haven't stopped smilling since, it was turning the whole room into a huge resonator.
i have a pic of my prototype if anyone is interested?
it's a bit rough, no sanding and finishing, it also has a piece of 2x4'' across the mouth .
this horn is so efficient i had to stand on the box (14 stone 89kg) to stop it from moving and it didnt stop it
![]() then i bridged the Dynacored amp, and had the biggest grin on my face
the closest i have heard to this bin is he big bertha, which is a huge mother
if i were to put 4 of these together it would out perform it with no barn doors (horn extension)
outside i had to stand it up, inside it was so much better on it's side using the floor as an extension
jethroker! it's been along time since i was excited about a project like this
![]() ![]() ![]() Edited by mykey - 02 February 2007 at 9:27am |
COWFOOT
Joined: 26 September 2005 Status: Offline Points: 1088 |
Posted: 02 February 2007 at 8:49am |
Hey Mykey: Let's have the pic.
mykey
Posted: 02 February 2007 at 8:57am |
mykey
Posted: 02 February 2007 at 9:09am |
these with say something like an HD15 i would have a clash with anyone, c'mon stikem up!
i kneeled on this box for about 30 seconds and almost lost my senses
![]() Edited by mykey - 02 February 2007 at 9:16am |
Page <1234 9> |
