  New Posts New Posts RSS Feed - TDA MT121 vs Original MT121
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2011 at 1:53pm
So basically recommended crossover of 800-1000Hz is about right, isnt it? So i was right saying that going higher will just make it worse.
it might not sound bad to the ears having a small dip at 1.5KHz but still we aim for a flat response, aren't we?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2011 at 2:47pm
this is true marjan, the highest you would want to cross them is 1.2khz with a bit of eq....  I ran 1 a side last week crossed at 1.2khz with the 2 inch comp from 1khz.. sounded very nice...... in real terms of use ability there is no differance in sound from the 2 versions..... only in the higher region which you will not be using......... In my view they are the best diy 12 inch horn there is, and ive build a few of the other diy plans for 12 inch horns....
SebP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SebP Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2011 at 2:14am
Have compared MT121 and MT-130 with same driver (RCF L12P110K), I think they sound similar in term of levels and quality (perhaps MT-130 is more sensitive by a little) but for sure, MT-130 goes higher.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2012 at 5:04am
\\\\\\recommended crossover of 800-1000Hz\\\\
650-800hz ,  4" VC driver   -)))
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 2:40pm
Originally posted by bee bee wrote:
in real terms of use ability there is no differance in sound from the 2 versions..... only in the higher region which you will not be using..........
So with "small" amount of eq, same drivers, the 2x could be made to play the same, yes ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 10:28pm
Lev i dont think there will be much difference between this and the classic MT box.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 11:19pm
yes lev...... there is only a differance above 1.2k, but in most cases you will be crossing over before you would notice the differance between the 2......
from 150 to 1k they sound the same....
Tweeter_Box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2012 at 9:42pm
offtopic: what happens to the freq response and spl if you enlarge the driver chamber in the standard MT121 by say 40% ? keeping the horn the same
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2012 at 10:17pm
may help to smooth it out a bit, but at the cost of spl.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2012 at 10:35pm
cheers for that bee Thumbs Up
benergy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote benergy Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2013 at 4:43pm
Can Someone please send me a link to the original mt121 with curved flare. I cant find them anywhere and have been looking non stop. I can only find plans for simplified version.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2013 at 6:21pm
there was never one with a curved flare.
http://www.speakerplans.com/index.php?id=mt122
that's the mt122, an mt121 is when you only use a single 12" section, and whatever horn / driver combo above.`
