Terminals on CIARE 12.00SWDCNDW? |
Crazy Dane
Joined: 14 October 2010 Location: Denmark Status: Offline Points: 303 |
Topic: Terminals on CIARE 12.00SWDCNDW?Posted: 17 October 2010 at 6:06pm |
Which terminals are used in this speaker?
Can see at thomann.de that it is soldering terminals. Is this correct? In my world, that is not a good thing to use on a high power woofer! Push-terminals is preferred.
Best regards... Frank
djyves
Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Posted: 17 October 2010 at 6:21pm |
If you don't want to solder them, you can use these:
Crazy Dane
Posted: 17 October 2010 at 6:28pm |
Okay.. Then it is soldering terminals.. Thats sad :(
Tony Wilkes
Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4835 |
Posted: 18 October 2010 at 10:02am |
They are not soldering terminals they are for push-on crimp tags.
It is not recommended to solder to a lot of these connectors as the insulating material often has a low melting point and you can destroy the connector or its surroundings. Tony |
Crazy Dane
Posted: 18 October 2010 at 2:46pm |
Can they rattle loose? I really don't understand why they have choosen this type of connectors.
They are pretty shitty |
abbotsmike
Joined: 28 December 2009 Location: Hillingdon, UK Status: Offline Points: 343 |
Posted: 18 October 2010 at 3:36pm |
Spade crimps probably hold a good deal of your cars electrics together. As long as they are the correct size and fit tightly they will be fine.
