THAM15 kick section |
teeth
Topic: THAM15 kick sectionPosted: 03 August 2023 at 4:59pm |
can anyone recommend kicks to run alongside a pair of THAM15
2 or maybe 4 if i can afford it. was considering paraflex 12s of some kind perhaps. would only need a pair i think as decent output. but open to suggestions.
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 03 August 2023 at 5:47pm |
what have you got for tops?
monkeypuzzle
Joined: 25 January 2005 Status: Offline Points: 1046 |
Posted: 03 August 2023 at 9:44pm |
I run between 2 and 8 Thams on my system. If you're looking at needing kicks, the than isn't really a sub so you'd be better looking for a different bass section. As mentioned, what are your tops?
FOO
Joined: 23 December 2018 Location: Denmark Status: Offline Points: 951 |
Posted: 03 August 2023 at 11:01pm |
Maybe Cubo Kick 12?
Very simple build, and if it's down the road of the big brother Cubo Kick 15, it will do a good job.
hectorberman
Posted: 04 August 2023 at 2:49pm |
Just build 2 more tham 15!
I find they play very well in the kick range
monkeypuzzle
Posted: 04 August 2023 at 10:58pm |
Agreed,whilst they don't have the real thump of a dedicated kick box they also don't have the sub that could sit under such a box. I built them because they're an efficient all rounder and I'm really pleased. Play with a bit of eq and dial in some kick. If it doesn't punch enough then build more 4 a side does really well) or go down a different route. They'll never be the 6 X1's and 4 FK1 218s I used to run but that's fine.,they take up far less space and need much less power.
teeth
Posted: 20 September 2023 at 7:21pm |
going for tham kick section as i can bring a pair of 218 to the battle easily enough.
i will run them up to 140. does anyone have delays to hand? i wasn’t able to find a definitive answer readily.
