  New Posts New Posts RSS Feed - THAM15 kick section
THAM15 kick section
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: THAM15 kick section
    Posted: 03 August 2023 at 4:59pm
can anyone recommend kicks to run alongside a pair of THAM15
 2 or maybe 4 if i can afford it.
was considering paraflex 12s of some kind perhaps. would only need a pair i think as decent output. but open to suggestions.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2023 at 5:47pm
what have you got for tops?
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2023 at 9:44pm
I run between 2 and 8 Thams on my system. If you're looking at needing kicks, the than isn't really a sub so you'd be better looking for a different bass section. As mentioned, what are your tops?
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2023 at 11:01pm
Maybe Cubo Kick 12?
Very simple build, and if it's down the road of the big brother Cubo Kick 15, it will do a good job.
hectorberman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hectorberman Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2023 at 2:49pm
Just build 2 more tham 15!
I find they play very well in the kick range
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2023 at 10:58pm
Agreed,whilst they don't have the real thump of a dedicated kick box they also don't have the sub that could sit under such a box. I built them because they're an efficient all rounder and I'm really pleased. Play with a bit of eq and dial in some kick. If it doesn't punch enough then build more 4 a side does really well) or go down a different route. They'll never be the 6 X1's and 4 FK1 218s I used to run but that's fine.,they take up far less space and need much less power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2023 at 7:21pm
going for tham kick section as i can bring a pair of 218 to the battle easily enough.
i will run them up to 140.
does anyone have delays to hand? i wasn’t able to find a definitive answer readily.
