  New Posts New Posts RSS Feed - The beginning of Bliss Soundsystem
 Post Reply Post Reply Page  <1234 17>
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2015 at 9:29pm
Deffo going for scoops over reflex after much thought. Double 15 reflex on kick duty and can use it as bass for small events Thumbs Up
You can't polish a turd!
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 12:16am
I thought that you would use those two sealed 2x12" for kicks and moreSmile
I am very satisfied on the sealed 12" I have playing above 18" reflex.
Im also getting used to the fat hifi sound of the reflex subs.
If you want weight go for reflex if you want loud go for scoops!
The sealed 12" are looking good still! Good luck with the project whatever you build!Thumbs Up
"what!?"
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 1:00am
If you want loud weight go for scoops!
fixed
Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 6:29am
What's above your double 12? Straight to comps? I play a lot of deep house and garage so most of the weight and flow of the music is in the kick band. So a proper kick section is needed.
Edit: failed quoting
Edited by cookie-dj - 22 June 2015 at 6:30am
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 10:40am
Im using the fane 12-250tc which play up to 17k. So nothing LOL
"what!?"
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 11:03am
17KHz is not bad for a 300mm driver, might get a bit beamy up there though LOL
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 12:25pm
Yup, spec sheet shows a 26dB difference between on axis and 45o off at 10kHz. Not knocking App for using it in a first build, especially as I think it's only being used in small spaces, but it certainly won't cover anywhere big consistently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 12:41pm
I think he may have meant 1.7KHz. At least I hope he did. Otherwise F1 would probably be making cabs with 12s behind axe heads.
app View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote app Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 2:50pm
In the club where I play I manage to get good coverage of the space with the midtops. They are quite directional but its not strictly negative thing. The club has 2 different spaces and because the midtops are directional theres not sound spilling to the other space which has the bar.
This means that people can talk in the bar and listen to music in the main "hall". Instead of getting the sound allover the place. They can cover a decent area when setup the right way. They sound good too since they have no crossover and its all paper making the sound.
edit. Aka. they have good directional control LOL
Edited by app - 22 June 2015 at 3:19pm
"what!?"
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 3:08pm
nope, Fane 12 250 TC is a real full range driver with a novel whizzer cone design. It has been throughly discussed in this thread:
http://forum.speakerplans.com/fane-12250tc-full-rangers_topic89634.html?KW=
 But yes, it apparently beams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 3:32pm
Ah gotcha, learn something every day.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2015 at 11:32pm
"But yes, it apparently beams. "
Of course it does.
Off-axis it starts rolling above 1Khz or so.
djk
