  New Posts New Posts RSS Feed - The beginning of Bliss Soundsystem
 Post Reply Post Reply Page  <12345 17>
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2015 at 11:20am
Mini scoops are here! MS46 by Marc'o
You can't polish a turd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2015 at 11:21am
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2015 at 12:20pm
Lookin sweet my good man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2015 at 2:19pm
MS46 heard tha deadly man loaded with 50s....nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2015 at 9:20pm
Cant wait to get some signal through the system! Does anyone know if the 1850 bolt pattern is the same as RCF???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2015 at 11:34pm
Pretty sure it is yuno, bcus had the same problem when a build 2 scoops for some one a while back and i asked the same question  on here, with no reply
so untill i had the driver in the flesh he was loading his with RCF LF18X401, and i checked it with a PD chassis , and sure it lined up correctly, inner bolt pattern ovis......
was a while ago tho....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2015 at 7:02am
I've got PD outer pattern on the scoops. Might just have to splash out on 1850s to be safe
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2015 at 7:50pm
Got 2x 2" boxes coming this week, will keep you all posted with pics of course
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2015 at 8:06pm
the older 1850's will fit, the 1850/2 does not. As pd have done away with the hidden inner bolts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2015 at 8:23pm
So the 1850 and 1850/2 are not interchangeable with the outer bolt pattern? seems crackers to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 6:09pm
New HF boxes are here! Build pics uploading now
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 6:16pm
Inside
