things to do on a sunday |
Page <1234 16> |
(SoundcreationaudiO)
Joined: 09 October 2007 Location: Wales Status: Offline Points: 306 |
Posted: 06 October 2008 at 10:47pm |
love the bracing csg, aggresive aesthetics.. suite the punisher nicely. I like the handles also... :)
csg
Joined: 17 September 2007 Location: bedford Status: Offline Points: 6085 |
Posted: 06 October 2008 at 11:29pm |
cheers - thats 4 sheets of birch sitting there!
i think im going for this bin - seems to be a good 1 box bass solution with the community box on top
so, 11 more to build! Edited by csg - 06 October 2008 at 11:30pm |
ceharden
Posted: 06 October 2008 at 11:52pm |
4 sheets for one double Punisher?!? Seems like a lot.
Have you considered alternative drivers? (not sure if I've said this before) I had a play with some simulations when I owned some Punishers which suggested you could change the character of the cab by using some different drivers. eg B&C 18TBX100 would give a flatter response, slightly more efficiency but slightly less output at the bottom end (limited by smaller x-max) |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 06 October 2008 at 11:57pm |
18tbx100? surely thats a typo???
insert silly sentence here
ceharden
Posted: 07 October 2008 at 12:14am |
D'oh! Yeah, I mean 12TBX100. Same motor, smaller cone.
Bespoke
Joined: 20 August 2007 Location: Gone Status: Offline Points: 1886 |
Posted: 07 October 2008 at 12:59am |
Is a lovely build |
csg
Posted: 07 October 2008 at 10:56am |
Cheers Tim, good to see you too. Chris - well, the basic twin plan comes out at exactly 3 sheets, but the end cheeks, and some aditional bracing inside uses another sheet. those end cheeks are 45mm thick!
In addition, this build is fully rebated which means that all the pannels other than the sides are 15mm wider than as shown on the plans. that adds up fast!
well, i know what you are saying regarding the drivers, but im a bit stubborn in this respect. the ciare driver is the only recommended driver in view of the designer, and is exceptionally well built, robust and cost effective.
the bottom end is also very important here as these are going to be used as subs, not with subs. im not prepaired to compromise on extention or low end output, so i think ill stick with the ciare
Edited by csg - 07 October 2008 at 5:18pm |
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 07 October 2008 at 1:28pm |
You are aiming for 12 doubles?
Hohoooo i would like to hear that lot. What damage do you think that pile can do? |
csg
Posted: 07 October 2008 at 5:16pm |
Im not aiming, it will happen - just been pricing up birch ply - 50 sheets of 15mm!
MarjanM
Posted: 07 October 2008 at 5:26pm |
Good luck then
![]() We will wait for the bull blast report. |
darkmatter
Joined: 26 February 2005 Location: LDN Status: Offline Points: 2419 |
Posted: 08 October 2008 at 5:21pm |
Cheers for posting pics, inspiring stuff.
Clearly designed after plenty of touring experience which is really useful for me to see having no experience myself :) |
csg
Posted: 08 October 2008 at 6:16pm |
yep, i never seem to stop moving kit about, so how things handle and pack are important considerations
this has not turned out that light - approx 105kg, but its a simple and easy 1 man move with a sack truck, as the weight is distributed in a good way. I think ill be able to get all 12 in my iveco, with mid highs, amps, cable and some lighting kit
think it might be slightly over weight though...
Ive had the bin running for a few days now, not at crazy volume, but its certainly bedding in the drivers, and sounding smoother and deeper. It sounds great with all kinds of music crossing at 105hz to the community sls920.
Page <1234 16> |
