Bose 302 Cabinets plans, any body ?? please |
Tinyzero
Joined: 19 July 2008 Location: Denmark Status: Offline Points: 11 |
Topic: Bose 302 Cabinets plans, any body ?? pleasePosted: 21 August 2009 at 8:12pm |
First of all, I must say I have always liked these cabinets from Bose There not going below 40 Hz acutely band pass limits to 55 Hz with active eq module But there have a fine strong bass not like horn or bass reflex systems at all I have been trying to get at set of plans for a very long time now, with out any luck Not even a picture from inside of the cabinets, are possible from google The cabinets using 2 x As I see it, its a 6 order band pass cabinets with joined bass reflex ports So any body help ! A set of plans for Bose 302 sub cabinets Edited by Tinyzero - 21 August 2009 at 8:19pm |
djyves
Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Posted: 22 August 2009 at 6:19am |
i am searching for the plan too
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 5992 |
Posted: 22 August 2009 at 6:52pm |
As usual, it would help to know what brand of drive units you can purchase.
BP6A enclosures are quite sensitive to driver parameters. Edited by _djk_ - 22 August 2009 at 6:53pm |
djk
Tinyzero
Posted: 25 August 2009 at 12:17pm |
Hi DJK
It is possible to buy a speaker with same T/S as the origianl speakers
so the plans / drawing af the cabinet is all i need
Tinyzero
fontaine
Joined: 06 January 2010 Location: canada Status: Offline Points: 2 |
Posted: 06 January 2010 at 6:19am |
hey, i'm in canada and have a pair of 302 sleeping in my basement...... ouch!!! cheers ! Francois.
djyves
Posted: 12 May 2010 at 4:51pm |
I am still interested, and looking for the plan.
"If brute force doesn't work, you're just not using enough!"
fontaine
Posted: 12 May 2010 at 5:18pm |
i'll be in touch with you soon .....
François.
The Builder
Joined: 03 January 2010 Status: Offline Points: 3107 |
Posted: 17 May 2010 at 11:48pm |
Put Ciare drivers in them.
It just is.
musicman
Joined: 21 October 2009 Status: Offline Points: 272 |
Posted: 18 May 2010 at 8:41am |
even emmi delta 12lf works!
fellamelad
Joined: 28 May 2010 Location: midlands uk Status: Offline Points: 13 |
Posted: 09 June 2010 at 7:00pm |
Hi folks justgot a pair of 302's off e-bay they have been fitted with Eminence Delta 12LFA drivers which have rubber surrounds and look very similar to the original bose drivers , i have only ever seen the deltas with paper surrounds and cant seem to find any info on the rubber surrounded ones any ideas ?
p1go
Posted: 09 June 2010 at 8:03pm |
HI
Here's the plans:
dougsand
Posted: 10 October 2010 at 1:16am |
Hi, Did you ever get plans for Bose 302? Thanks, Doug
