X10 vs mt122 what would you use to go with ES18BPH |
Page 123 5> |
C-Audiofreak
Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
Topic: X10 vs mt122 what would you use to go with ES18BPHPosted: 07 December 2014 at 11:07pm |
Hi guys I was going to build four of the mt122 cabs to go with my ES18 bph kicks and X1subs but have found that the original spec drivers that the plan states are no longer available but I can get everything for the x10 cab which would fair best with the kicks and subs I have mentioned?
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 08 December 2014 at 12:05am |
most drivers will work with the mt122 or mt121
just ask the forum which drivers they would recommend for the mt122 |
Heathrow_B_line
Posted: 08 December 2014 at 12:10am |
PD121, PD123ER, B&C 12PE32, B&C 12NDL76, 18SOUND 12ND710, BMS 12S310, BMS 12S610, ETC New P AUDIO 12" drivers are out too. Im not sure what the model number is...possibly P-Audio SN2-12MB8Edited by Heathrow_B_line - 08 December 2014 at 12:12am |
DjLeco
Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 820 |
Posted: 08 December 2014 at 8:26am |
Selenium 12MB3P.
Edited by DjLeco - 08 December 2014 at 8:27am |
I'm A Stupid SMART Romanian...
C-Audiofreak
Posted: 08 December 2014 at 10:11am |
Do you think 1 pair of mt122 would be enough th go with four x1 and 4 ES18BH ? Or would I be best going for two pairs?
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7508 |
Posted: 08 December 2014 at 11:22am |
the only reason to have 2 pairs of mt122 would be to cover a wider area really.
i've had 1 mt121 per side above 2 X1 and 2 double 15 a side.. has done fine. |
Heathrow_B_line
Posted: 08 December 2014 at 12:01pm |
the x1 will run out of steam before the es18 or mt122 or mt121 |
king david
Joined: 17 January 2007 Location: italy Status: Offline Points: 1329 |
Posted: 08 December 2014 at 3:55pm |
+1
but that is largely dependent on crossover points and music selection
http://www.warriorcharge.noblogs.org
C-Audiofreak
Posted: 08 December 2014 at 5:58pm |
Why will the x1 run out of steam I'm hoping to run them upto 70hz then the ES18BPh 70-250hz and the mt122 250hz and up it will be mainly used for general purpous indie and rock and be used for general dance music when I'm dj'ing through it if these crossover points are wrong please advise me how I should set it up I want to get it right as sound quality is king for me and those using it I have already built the X1 subs so am committed with the sub end
cookie-dj
Joined: 09 May 2014 Location: Warwickshire Status: Offline Points: 975 |
Posted: 09 December 2014 at 6:17am |
Neeeee naww someone's called the grammar police!
The MT's can outrun the x1, hence why you'd usually have 4x X1 (or even 4x 1850 horn) per MT. Cant really compare reflex tops to horn loaded, horn loaded will run rings around reflex tops outside though. Depending on its usage, indoor/outdoor etc. |
You can't polish a turd!
C-Audiofreak
Posted: 09 December 2014 at 10:21am |
Ok so maybe I will just build 1pair of 122's then will two es18 be enough for four x1 and one pair of mt122?
cookie-dj
Posted: 09 December 2014 at 11:12am |
Possibly. what are the ES18 loaded with?
Page 123 5> |
