  New Posts New Posts RSS Feed - UK Box Builder - PCH Audio
Audio_Stash View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Audio_Stash Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2015 at 11:10pm
Its all 18mm MDF. Just strips around the front to give the chunky look.
Some bracing and baffles are made from 2 18mm panels laminated to form 36mm pieces.
The scoops are very easy to move around on your own with the wheels.
Thanks for all the kind words........ more pics to come
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_Stash Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 12:22am
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 1:10am
I see you put clamps on all your scoop drivers ,do you prefer them just for easier swapping or?
Got some drivers to swap try out with different patterns so just wondering,the clamps dont feel they can go tight enough.Correct me if im wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_Stash Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 1:25am
Those scoops we're originally t-nutted for Fane (outside bolt circle).
It was easier and made more sense to use clamps with the existing holes when swapping to Oberton drivers, rather than fill those holes and drill new ones.
The drivers are fixed in as tight as they would be using the bolt holes. I had to fit a rear gasket on the drivers because they don't come with any.
Edited by Audio_Stash - 30 April 2015 at 1:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_Stash Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 1:41am
On page 1 there were some talks about magic paint and turning wood into other wood...
This doesn't really tie in to the crisp clean edges and black textured paint shown normally, but here is a little experiment I done. Just thought I'd share.
This is a bit of standard MDF, made to look like the finish found on old vintage reggae sound system boxes. The damage was inflicted purposely.
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 2:22am
Originally posted by godge godge wrote:
Yeah it's mdf but who cares, awesome build, great skills
A lot of people care. Cabs have to be solid, and mdf is much easier to work with. E.G. Sanding, routing, cutting.
plus you don't have to sell straight after purchasing.
Mykey Wattco
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 8:26am
The pic is MDF? How have you achieved this result if I may ask? Especially the woodgrain?
It's beautiful
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
DanielIt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielIt Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 8:38am
I think you just sand in only 1 direction before painting it.
Measure twice...cut once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 10:45am
So what MDF is not a solid build? course it is man come on, there nuff cabs made out of MDF over the years and still going strong,
know of MDF cabs being used for dancehall, parks , carnivals, outdoor fare's being moved all over europe to play sessions and still going man
just need a little care , sick off saying it , only replying to peeps echos on here keep on about it too...
Great works Venny , bring a little diff to the table , im all for that , nice!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_Stash Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 12:47pm
Mykey I've always had MDF boxes. They have always been fine.
If people are not prepared to pay for birch ply then it is MDF they get. I Wouldn't build a box from hardwood ply or anything like that because it is no good.
You could say something like good effort keep it up, but no ofcourse not because you're mykey. You chuck some negativity at me. ain't nobody got time for that man
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 2:02pm
You are all still too green. You need a few more years experience
Mykey Wattco
Andy Kos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2015 at 9:24pm
Sometimes experience means people get stuck in their ways...
there is no harm in doing things a little differently, if it works and user/customer is happy you cant really argue with that.
I have build boxes from ply and MDF, there are pros and cons with both. One of the best results I ever got was a 2x15" cab made from 25mm MDF - weighed a ****ing ton but it sounded real nice. MDF is denser than ply, and since this job was for install, how it fared on the road was not at issue.
Used correctly, MDF is just fine.
MDF can struggle a bit if not correctly sealed and protected, once it scuffs and allows moisture in it will tend to expand a little. MDF isnt perfect for a hard life on the road, but if you look after your kit, it's just fine.
Edited by Andy Kos - 03 May 2015 at 10:01pm
