  New Posts New Posts RSS Feed - Us Boys from Round Yonder (Somerset)
 Post Reply Post Reply Page  <1234 5>
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2010 at 4:55pm
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2010 at 5:56pm
Was it running out of truss or headroom in the marquee?
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2010 at 6:14pm
Seems to be the case of last one. It is one support around stage and back line seems to run out of clearance. And because of that front line is left out because it would have been to low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2010 at 6:21pm
We only used the front 3 ways purely to get the extra 500mm or so to stick some cans on to was the front of stage. Height was a massive issue tho :(
Was still around 20 meters of truss on the van.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2010 at 8:59pm
You can get horizontal corners in bilite, handy to have in stock for these moments. Rake the sides to get more clearance. Not cheap though I know
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2010 at 9:38am
Yeah thats a good idea. Im still learning loads with the whole lighting thing. Have been rigging it for years but the whole design thing i find really hard as I dont seem to have that natural arty flair so have to try even harder. May mate James is very good he does most of our lighting.
Alimon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alimon Quote  Post ReplyReply Direct Link To This Post Posted: 26 August 2010 at 7:09pm
you guys from somerset? and have 1850's? (void loaded?) heard of us (digga sound) we're from taunton and have 8 1850's with xtro tops and void infinate amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2010 at 12:19pm
yeah were from somerset and have 32 x 1850s loaded with 18xb have a mixture of amps, Void, MC2 & PSL
Yeah ive heard of you guys, guy i work with knows you i think? Chris Alpin? I was at UK-Tek in may and saw your system, sounded nice! better than the Void rig did!
If you ever need more 1850's drop me a line im sure we could sort something out.
JTB
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2010 at 12:34pm
32! Big smile
Have you thought of replacing the XBs with 1850/1851 or V18s at some point?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2010 at 1:39pm
Yeah there will be 1850's going in them at some point, Just waiting for a bigger company to do a driver replacement so we can bulk buy second hand cheap.
To be fair the XB's are doing us fine as we rarely go out with less than 6 a side so couple together, any less than 2 a side dont bother then sound wank.
backlash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backlash Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2010 at 6:34am
yeah were from somerset and have 32 x 1850s loaded with 18xb have a mixture of amps, Void, MC2 & PSLYeah ive heard of you guys, guy i work with knows you i think? Chris Alpin? I was at UK-Tek in may and saw your system, sounded nice! better than the Void rig did!If you ever need more 1850's drop me a line im sure we could sort something out.JTB
I have known young chris applin for years now!
Sound Hire
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2011 at 9:57pm
