  New Posts New Posts RSS Feed - V18 cut out
V18 cut out
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 9:31pm
Oh, just seen it's inside an 1850..
Right angled rasp it is! Find a small child and get them to do it for a mars bar Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 9:49pm
Otherwise an angle grinder with an very low grit wheel. (<25)
I think you can also get wood wheels.
Edited by infrasound - 29 June 2012 at 9:49pm
Amplighting&sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 10:19pm
Do well will try the grinder just dont want it to look messi
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 10:42pm
can you using a jigsaw turn jig saw upside down and slowly notch out loads of lines 5mm deep then use a very sharp chisel to knock them out..... hope you get what i mean........
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 10:45pm
should of said with an extended blade, ill do a quick google search for you and find a link to what i mean.....
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 10:46pm
http://www.google.co.uk/products/catalog?hl=en&safe=off&rlz=1C2AFAA_en-GBGB434GB455&q=jig+saw+blade&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1280&bih=685&um=1&ie=UTF-8&tbm=shop&cid=7529241557775812567&sa=X&ei=9SHuT_GzFYz58QOc5dCqDQ&ved=0CH8Q8gIwAw
this way you can get the jigsaw in there...... just take your time....... as you will be doing it free hand with the jigsaw in free air..... i.e. base not touching wood.....
Edited by bee - 29 June 2012 at 10:48pm
Vert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vert Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 10:47pm
Box builder, pm for quote
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2012 at 10:57pm
Ok nice one boys ya get what ya mean thank u will try it first thing in morning
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2012 at 8:16pm
Hello people of the 1850s lol 5 down 3 to go best way is routa half and grider with flat wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2012 at 6:49pm
Hello all 8 are now dun just need to wire them up ready for saturday
