Void inf8 Mk1 - early or late version? |
Page 12> |
| Author | |||
LBD
Joined: 25 April 2024 Location: Doncaster Status: Offline Points: 18 |
Topic: Void inf8 Mk1 - early or late version?Posted: 01 May 2024 at 8:10pm |
Does anybody know if there's any telltale signs of whether an Infinite 8 mk1 is the early version or late version? I've read that the early version doesn't do well at 4r bridge which is what I intend to use it for. I'm looking at getting a secondhand one but the seller only has a few photos of the outside of the amp.
Thanks
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 02 May 2024 at 9:18am |
Only Void Infinite 8 Mk1, even worth considering, is one with paperwork certified, upgrades done.
I've been following them from over 17x years ago, when first ones came out, and were catching fire. I wouldn't take one, if it was given to me, for free.. |
LBD
Posted: 02 May 2024 at 12:20pm |
Thanks for the info I appreciate it. My other options for sub amp are a Proline 3000 or Infinite 7 mk2. Which do you think is best to run 2x Turbomax 1500 18s in 4ohm bridge? Cheers
levyte357-
Posted: 02 May 2024 at 12:28pm |
Which cabs do you have? Do you already have the drivers? I'm well acquainted with these drivers, and can tell you from experience, you will get poor returns for your money, if they are not in the right cabs. |
LBD
Posted: 02 May 2024 at 12:34pm |
I have Shortman deep chamber full size 18" scoops.
levyte357-
Posted: 02 May 2024 at 3:08pm |
Yep know the ones.. Few years ago, I heard Dance hall Reggae Crew, playing 4x of these loaded with Tmax 1500s.
Up close, they were thundering, 5M away, could barely tell cabs were on. This is the problem with Tmax 1500s, unless in cabs, absolutely optimal for them. |
LBD
Posted: 02 May 2024 at 3:30pm |
That sounds strange. Never noticed that with the scoops Iration Steppas had back in the day which were shortman and tmax 1500. But anyway, do you reckon proline 3000 or infinite 7 mk2 for 2 scoops with those drivers?
levyte357-
Posted: 02 May 2024 at 3:39pm |
If you always play 2x or more stacks, will be less of an issue. Proline 3000 was great amp for bridging back in the day, I coined the phrase here "Bridge monster", because of it. But if you ever see the clip light, you have shortened the life of your drivers. 2x Tmax 1500 in bridge, will easily drink all that power, and make it clip. Void Inf7 Mk2, was never really well respected as a sub amp. Would suggest QSC 5050, or Crest CA18, if you are intent on bridging.
luton_soundman
Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4550 |
Posted: 02 May 2024 at 5:58pm |
1500s dont do anything below 40hz so make sure you hpf there and dont waste energy flapping the speaker around with nothing nice coming out of it. If you want the notes below 40hz sell them off and upgrade.
levyte357-
Posted: 02 May 2024 at 6:22pm |
Completely agree.. ![]() With the right Scoops, and PD1851s/1852s, and Void Infinite 8MK2, effortless notes and SPL. My mate spent 2x years trying to get decent sub with Tmax 1500s, in Shortman Minis.
Went back to PD1850s, and then spent next 4x years, just making money. |
LBD
Posted: 02 May 2024 at 6:29pm |
Thanks, will look out for a second hand CA18, doesn't look like they come up often though.
LBD
Posted: 02 May 2024 at 6:31pm |
Do you know which 1500 tmax drivers they were? The Red I 1500 is the one for larger chambers so it'd make sense if they had the 1500i and it didn't sound great in a shortman scoop.
Page 12> |
