Void Stasys X V1 - Ferrite vs Neo. |
| Author | ||
Shadrack
Joined: 04 February 2017 Status: Offline Points: 46 |
Topic: Void Stasys X V1 - Ferrite vs Neo.Posted: 11 October 2018 at 7:47pm |
Hello there.
I currently have 6 Void Stasys X V1s. 4 cabs have the Wooden ports on them, Loaded with the Void v-1400 Neo The 2 other cabs have the Plastic Ports and loaded with Void v-1400 Ferrites. When I play all 6 together, its no way near as loud as when I play the 4 neos on there own. I put it down to phasing problems if im correct? due to there being two different drivers and maybe difference in the two cabs designs ? Im looking at buying 4 void news to re-load into the ferrite pair. I got told the cabs are same design and this would be fine. can anyone shed some light? Thanks !
I-shen Soundboy
Joined: 21 December 2016 Location: Big Smoke Status: Offline Points: 375 |
Posted: 11 October 2018 at 9:07pm |
Wild shot in the dark here: Could the wiring
Edited by I-shen Soundboy - 11 October 2018 at 11:36pm |
Guests
Guest
Thanks(1)
Posted: 11 October 2018 at 10:59pm |
Wrong polarity
Father-Francis
Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2758 |
Posted: 12 October 2018 at 12:15am |
drivers shouldn't give you that kind problem , i know cause we are runinng magnets in same kind of cabs with no sound problem just weight difference , cross check all cables in and outside the boxes
Speaker Sol
Joined: 15 September 2009 Location: Ireland Status: Offline Points: 1326 |
Posted: 12 October 2018 at 12:55am |
Yep i ran mix of ferrite and neo Stasys x for years. No problem.
Something else is going on.
Noizyboysoundz
Posted: 20 May 2019 at 5:52pm |
have you sold the v18-1400 ferrite drivers, and if not could I get a pair, just wondering
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 20 May 2019 at 7:00pm |
Never saw this thread at the time, but the cabinet with different drivers absolutely has different magnitude and phase response, so it will not play the same as using all of the same type in one stack. |
Speaker Sol
Posted: 22 May 2019 at 9:55am |
With all due respect, I think you are over stating the effect. Yes of course, the use of different drivers will have slight differences in phase and magnitude. But these differences are small and won't course the type of effect that is being stated (a large drop in output). I know from experience and measurements, that the ferrite and neo drivers will sum just fine without any major issues with the response. Maybe the issue lies with older cabs with the 'plastic' ports? However I once used a pair of these along side 4 'standard' Stasys X, I didn't notice any issues at the time, but it was a long time ago... I still feel that something else is wrong with the ops setup. |
Speaker Sol
Posted: 22 May 2019 at 9:56am |
'With all due respect' <- Just to be clear, I meant that sincerely.
marv203
Posted: 29 January 2025 at 11:29am |
Hi,
I am working on a preset for Void Stasys X v1 Neo version. I use: Hi Pass : 30 Hz - 24 dB/oct But Lo pass : 120 Hz - 48 dB/oct LR but I am not sure for the limiters. The powersoft calculator say following: RMS voltage 74 V Attack Range 2-4 seconds Release Time 4-8 seconds Peak Voltage 169 V Attack Time Range 16-32ms Release Time 128-384 ms Clipping voltage 222 What are you using, because I am not quite sure if this fits for those subs? Edited by marv203 - 29 January 2025 at 9:26pm |
smitske96
Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1217 |
Posted: 29 January 2025 at 7:24pm |
How did you conclude those settings are not accurate?
marv203
Posted: 29 January 2025 at 9:34pm |
I didn't choose the right expression. My question is rather whether this is suitable for the subs or would you set other limiters?
