  New Posts New Posts RSS Feed - What is the fault with SCOOPS
 Post Reply Post Reply Page  <1 2345>
Freddy Hopper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddy Hopper Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:49am
Thats the ASS scoops.  when they play, to me they are so clear and defined.
TAIL LIFT
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:49am
Thought someone said recently, Luv Injection had switched to FFA amps?
Nope - Running both FFA & Crests for a few years now
Originally posted by Freddy Hopper Freddy Hopper wrote:
Luv Injection Carried out 24 recently made scoops, 12 aside.  Klark Teknik, with these purple F something amps plus Crest to the teeth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddy Hopper Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:50am
Im quite sure the main stage was an EAW system.  two stacks of Nine folded something or other.  and two line arrays of mid and tops.
TAIL LIFT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:51am
A next reggae sound system who normally rumble up the place with ASS scoops is Lord Gelly's. Serious system!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:53am
Did you take a listen to it ? Cause whatever it was it sounded like sh*t!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddy Hopper Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:53am
Although at times Wayne Irie could have been mistaken for a stage show.  The way he was jumping round the amp boxes.  Very entertaining though. Alot of times he wont stop talking over the tunes and kills the vibe for me, but at carnival I was quite impressed.
TAIL LIFT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddy Hopper Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:55am
Yeah,I wasn't impressed either.   I walked round and it sounded even.   just evenly sh*t.   The perfect set for me would of been.  New Sensation Subs with Luv Injections Mid/Tops.
TAIL LIFT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 10:58am
Fe real - That would make a perfect match
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 11:11am
Originally posted by adambomb adambomb wrote:
Jah tubbys had 4 scoops in each stack, ninebar stack was 12 labs.
4 x 18''s against 24 x 12''s
Jah tubbys on the other hand... step 10 - 15m out and it's not all that anymore.
Maybe with JTS - I've mentioned before, I once heard a system called Logic using 8 of Mykey's Wattco scoops on a stage in Burgess Park Sth London.
Trust me, since that day, I ain't heard bass like that ever again from scoops outdoors. None of my mates could believe what we heard from the main road on approach to the park, & that distance I couldn't even measure it was so far away.
That's why the reggae man dem ain't letting go some certain types of scoops!
Big up yourself B, who have them scoops right now & ain't gonna let them go.
If Mykey gives me a chance to hear the DubSub one day, I'm sure it'll be something for me to remember. But everytime I ask him bout it, I get no response.
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 11:43am
Originally posted by Disco Stu Disco Stu wrote:
From my perspective its all about the amount of SPL that can be achieved from a box of a certain size. If I turn up with 3 scoops or 3 HD15s and a couple of labs (basically a similar size), which one am I going to get an overally better sound from in your opinion?
Unfortunately, there is no 1x18 cab around, that provides the sensitivity of a scoop, and the accuracy of a folded horn. I tried desiging a worthwhile 2x18 WSX with scoop like SPL in 1x cab, but 90% of people on here advised against it.
If I had things my way, I would love to do all my gigs inside and out with 2x stacks of 6 WSX; I love this cab.
Unfortunately, I have witnessed many times what 2x stacks of 3 scoops can do, even in huge halls. So if I turn up with 12 folded horns to most large gigs, customers  are gonna ask me why so many cabs, even worse, see 12 cabs, and expect 12 scoops worth of SPL.. Then come over to me at the end of the gig, and say how some crew came in with 1/2 the cabs, and sounded much heavier.  They won't be impressed at how clean and accurately the music was reproduced.
So the options for me will be: medium to large venues is 4x scoops or 8 folded horns, large/outside venues either 8x scoops, or 12 folded horns.
However, I'm sure "n" folded horns @ 1k each will be fine for any corporate gig. As they are often full of people who listen to hi end hifi outside work hours.
Design has moved on since the WSX mainly due to people wanting lots of low bass - hence the development of the labsub, the WSX isnt really any better than an 1850 in terms of extension. I think people are finally realising that having vast amounts of 30Hz isnt really that useful to you, since there isnt a lot going on down there anyway and you need exponential amounts of power to get that frequency up to the same level as the others, as far as I am concerned so long as you have something of a fundamental present even if its 10dB quieter it still has an effect on your perception of the subbass, if it isnt there at all (such as with a single CV folded horn) the sound is far less likely to fool you into thinking there is more subbass than there is. This is why I think the BFM Titans are doing so well - look at the response, nice peak at 100Hz, smoothly descending to a fundamental at 42Hz which is a lot quieter, yet a lot of DJs are using them over the Tubas (which were designed for that purpose). I would be willing to bet that the Titans actually work quite well for old skool reggae and dancehall.
As mykey says stick a boost at 63Hz and your perception of a fat warm tubby sounding bass will go up exponentially.
As to using folded horns vs scoops, scoops are always going to appear louder up close, the scoop has the edge in the upper bass because of the direct radiating driver causing more distortion. Its also going to be kicking air at your chest level from having the driver elevated and its going to have a myriad of phase problems in the bass/midbass region with the horn and driver interacting which is going to give a very sludgy sound which may well be just right for some types of music
The benefits of a scoop I think are best used in an indoor confined space up close, I get the feeling unless you have enough of them to form a sufficient boundary you dont get quite the same effect a few metres away outdoors. The combination of features of a scoop I am sure do make it suitable for some types of music. But the aim of a speaker system designer is to design a system which is able to reproduce the music you feed it accurately and a scoop does not (and indeed is not designed) to do this, which makes this genre, and this cab somewhat unique which is why it will continue to remain.
Stu
All you need to know is:
My acts:
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 1:01pm
Not quite correct, 2x WSX will easily reach 40hz with decent amps, and low cut at 80hz.
Many clubs use WSX in pairs with no perceivable lack of sub. 7ft vers 5.5ft horn. Wink
Yes, however decent scoops in pairs reach down to 35hz effortlessly, so driving them with beasty like 9001 or VZ500 is not really an issue here. Also increasing amounts of dancehall, rnb, hip hop have plenty of 32-40hz action going on, to the point of your system sounding lacking if it can't reproduce at least downto 35hz @ -6db.
To be quite honest, 63hz is really for the 1980's and upto mid 1990's. Modern scoops excel in the 40-50hz, because it sounds much lower than it is, and impacts limbs and buildings.
They also excel playing Old skool reggae. As I said before, the only other 1x18 cab I can say the same of is the WSX.
<SNIP>
Try  reading the carnival thread to hear what the ASS, V18-1000 scoopers sounded like outside, in "small stacks", and from distance.
"Most" Sound systems have moved on from valve amps to stuff like Crest, Crown, Void, Chevin, because they do the job more efficiently. If scoops were only any good close up or indoors, Most Sound systems would have moved on from them to folded horns, and you wouldnt hear scoops at carnival every year, getting louder and deeper, further away.
Also, not everyone knows how to correctly drive and tune scoops for their optimum performance. Therefore only ardent soundsystem designers/followers, who have attended many gigs, will know exactly what scoops can do, and where they are best used.
Edited by levyte357 - 17 November 2007 at 11:32am
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 1:52pm
Originally posted by Chris I Rockas Chris I Rockas wrote:
Mykey, I got a bit disillusioned a few years back and put everything up for sale, but fortunately no one bought them. They are all safely in storage waiting for my next session.
you lucky man, I'm glad you kept it the sameClap still love those twin cones me
